First, I want to apologize for any strange grammatics in this text, because I’m not a native english speaker.
Well I have a problem in a kernel like this (some things of it makes no sense, but ignore it).
int iy = blockDim.y * blockIdx.y + threadIdx.y;
int ix = blockDim.x * blockIdx.x + threadIdx.x;
int idx = iy * gridDim.x + ix;
int i = 0;
d_resul[idx] = 0;
if (idx <= size_val)
d_resul[idx] = d_val[(int)d_ptr[idx]+i] * d_vector[(int)d_ind[(int)d_ptr[idx]+i]];
After execution, all computed elements of d_resul was 0.
So I went to check if there was errors in the 2 operands of the multiplication: “d_val[(int)d_ptr[idx]+i]” and “d_vector[(int)d_ind[(int)d_ptr[idx]+i]]”.
“d_val[(int)d_ptr[idx]+i]” was OK, it was returning the number it should.
“d_vector[ (int)d_ind[(int)d_ptr[idx]+i] ]”, however, was always returning 0. It shouldn’t return 0.
So I decided to see which position of the array d_vector it was accessing. In other words, I tested “(int)d_ind[(int)d_ptr[idx]+i]”, and it was returning the number it should.
SO, the error must be in the d_vector array. But it is not. I have tested d_vector and it’s ok.
In other words, the following happens (example):
(int)d_ind[(int)d_ptr[idx]+i] is 5
d_vector[5] is 10
but d_vector[(int)d_ind[(int)d_ptr[idx]+i]] is 0, when It should be 10.
