Vehicle-detection Issue in Deepstream_NvDs_Analytics
Hi Team,
I am facing a issue in vehicle detection and counting in “deepstream_nvdsanalytics” of deepstream-6.1.1 SDK, implemented on Jetson-Orin-AGX-Xavier Devkit of L4T 34.1.1.
Issue Description:-
In deepstream_nvdsanalytics, I have designed the OSD Configuration for a highway videos , Using its properties namely ROI, Direction and Exit count.
Where, In the Line-Crossing Exit Count I have noted a Issue that is, “number of Exit-count is not Equal to number of vehicle count” that is, Multiple times of Vehicle Detection and its counting is happening for same a vehicle. -------> This I observed in the highway video with countable vehicles.
Deepstream application includes all the fast videos, and So, how to find a accuracy of object detection and counting?
@AastaLLL @yingliu @DaneLLL @WayneWWW @VickNV @ShaneCCC @JimWang
please, let me know to resolve the Above Issue that, I have mentioned?
To get better help, we are moving this topic to DeepStream forum.
Thank you.
Can you post your videos and configurations for us to debugging the issue?
Hi Fiona.Chen,
I have changed OSD part in Deepstream_nvdsananlytics that is, ROI Specification, Direction and Line- crossing Exit count.
config_nvdsnanlytics.txt:-
config_nvdsanalytics.txt (3.4 KB)
Video:-
Thanks,
Chaithra
The deepstream-nvdsanalytics-test is just a sample and it is open source. Can you change the nvtracker configuration in the source code /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-nvdsanalytics-test/deepstream_nvdsanalytics_test.cpp to another for a try?
Chang g_object_set (G_OBJECT (nvtracker), "ll-lib-file", "/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so", "ll-config-file", "../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml", "tracker-width", 640, "tracker-height", 480, NULL); to g_object_set (G_OBJECT (nvtracker), "ll-lib-file", "/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so", "ll-config-file", "../../../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml", "tracker-width", 640, "tracker-height", 480, NULL);
You can also tune the tracker parameters for better tracking result according to NvMultiObjectTracker Parameter Tuning Guide — DeepStream 6.1.1 Release documentation
Hi Fiona.Chen,
I have Tried and Checked the Changes you have mentioned but still the Issue is same and I have Tried with Changing the “maxShadowTrackingAge” and I have checked with “minTrackerConfidence” that is also in " Active mode" and I have set the “minIouDiff4NewTarget” to lower and Increased “minDetectorConfidence” values to higher to track the false detection values of “config_tracker_NvDCF_accuracy.yml” file. But, I am Not able to see any progress updates in it, the issue is still same
I will also keep trying it. please, Let me know if their is any updates about it to solve this issue.
Thanks,
Chaithra
I’ve tried with DeepStream 6.2, I found no count issue. Can you upgrade to DeepStream 6.2?
