Verifying CUDA Install
I have just installed NVIDIA driver, CUDA Toolkit and gpusdk on Ubuntu 11.04
I verified the installation of nvcc and its perfect. The problem is with gpusdk. I followed the guide
When I try to “make”, I get following error.
root@Lenovo-B560:~/NVIDIA_GPU_Computing_SDK/C# make
make[1]: Entering directory `/root/NVIDIA_GPU_Computing_SDK/C/common'
src/cutil.cpp:28:27: fatal error: builtin_types.h: No such file or directory
compilation terminated.
make[1]: *** [obj/i386/release/cutil.cpp.o] Error 1
make[1]: Leaving directory `/root/NVIDIA_GPU_Computing_SDK/C/common'
make: *** [lib/libcutil.so] Error 2
Can anyone guide me what the problem can be as i have to really start writing simple problems.
I’m having the same issue. If anyone can help, or has suggestions they would be greatly appreciated.
Greetings,
I am having the same issue. Followed the instructions to install latest driver and toolkit and sdk under Ubuntu 10.10
I end up with the following when I try to follow the guide and compile the sdk:
src/cutil.cpp:28: fatal error: builtin_types.h: No such file or directory
make[2]: *** [obj/x86_64/release/cutil.cpp.o] Error 1
make[2]: Leaving directory `/home/sarikan/NVIDIA_GPU_Computing_SDK/CUDALibraries/common'
make[1]: *** [lib/libcutil.so] Error 2
make[1]: Leaving directory `/home/sarikan/NVIDIA_GPU_Computing_SDK/CUDALibraries'
make: *** [all] Error 2
Problem solved. The solution at this address: Google Code Archive - Long-term storage for Google Code Project Hosting. worked for me. Just in case someone else faces the same issue.
I did not use the default directory for my toolkit install, and that is probably the reason I’m having this issue.
Just in case that page goes away at some time: make CUDA_INSTALL_PATH= solves the issue (where parent directory is the directory that contains include directory, which in turn includes the header file)
Kind regards
Seref
