Everything is good except when I reached section 2.5.1. Here, I try to run the deviceQuery program located in C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5\bin\win64\Release, the command prompt is giving back the message that C:\ProgramData\NVIDIA is not recognized. I did set “ProgramData” to visible mode but it didn’t help. The folder itself is not recognized even though I can open it.
Or, first navigate to the folder in question in the command prompt. (This may also require the use of quotes at some point, depending on how you navigate) Then launch the deviceQuery program just by typing:
