I’m trying to get Plant 3D 2019 to run on a Windows Server 2016 Quadro Virtual Workstation in Azure.
The host is an NV6, 6-core, 56 GB RAM with a Tesla M60 GPU.
When I connect to the server with remote desktop 3D rendering works in other apps and GPU is active. In fact Plant 3D shows the GPU as active and enables hardware acceleration however, performance is so bad (I get 2 - 3 FPS) it’s not even workable. When I disable hardware acceleration not much changes, which makes me assume the GPU is not being used at all.
Am I doing something wrong here? I also posted this on the Autodesk forums.
You mentioned that other applications are rendering as expected. Do you experience the low frame rates on other applications as well, or is the low FPS only observable with AutoCAD Plant 3D 2019?
