I found the cause of the problem. When setting mdev to be used by GPUS, I was setting a L4-4B flavour… For computing nodes it is needed a Q flavour, now I am using a L4-8Q and it is working fine.
I am sorry, I say badly the term, I was not talking about openstack flavour, the correct term is Nvidia vGPU profile.
Once you install your Nvidia grid driver you will notice that there are several vGPU profiles and you can only use the *Q and *C to be used as vGPU for vWS.
