Hi Christian,
as usual you get our GRID drivers in the GRID Portal:
https://nvidia.flexnetoperations.com
Latest GRID drivers are 385.90 from GRID5.1 package.
regards
Simon
Thank you very much Simon,
but i cannot found this drivers in https://nvidia.flexnetoperations.com/control/nvda/viewRecentProductReleases
i found only 4.3
why?
ok
i found the drivers requesting a trial.
Now i dont receive anymore the same error from the capture samples.
I receive this error now:
Unable to create CUDA context (result: 999)
i installed the cuda toolkit 9…
whats the problem now? :-(
Which profile are you running? Tesla M60 only supports CUDA with 8Q profile or Passthrough. Seems you’re using the wrong profile.
Regards
Simon
I was using 0Q profile. Now i’m going to reconfigure the VM and now it works!
But if i want to use NVIDIA Capture SDK i must use the 8Q profile? This is only for a dev environment or also for my own Capture custom client?
For example VMware Blast Extreme need an 8Q profile?
Thank you very much
As I said, Maxwell GPUs don’t support CUDA for vGPU. This was introduced with GRID5.x and Pascal GPUs.
I tried VMware Horizon 7 with Blast Extreme.
I created a CentOS desktop with M60-0Q profile and it works with H.264 blast protocol but …
I dont understand why the NVIDIA SDK require 8Q profile and Horizon 7 works with 0Q profile.
VMware Blast Extreme dont use the same Capture SDK?
thank you very much!
