I’m currently using Gstreamer on a Jetson TX1 and TX2. I have a video encoding pipeline which uses the omxvp8enc hardware encoder. I stream the compressed video over a network where bandwidth usage is an important consideration.
For the omxvp8enc, there are two settings of interest: “quality-level” and “bitrate.” How do these settings interact with each other? Is there a range for the bitrate when the quality-level is set to a certain level (for example “0”)? I couldn’t find any information on this in the documentation.
It would be very helpful to get an idea of how the quality-level setting corresponds to bitrate ranges.
DaneLLL, thank you for the clarification. I think it would be really helpful if you added this information to the encoder’s documentation:
“Under same bitrate, video quality is better but encoding speed is slower in SlowPreset.”
I think this would disambiguate the parameter settings for the encoder. I see other developers have had similar questions related to these settings.
One more clarification then, if the bitrate is not set and the preset-level parameter is used, what bitrate will the encoder use? Will it default to a preset value?
Please share which Jetson platform you are using. The later platforms do not have vp8 hardware encoder, so if you have to encode to vp8, would need to use software encoder.
