Hi everyone,
I couldn’t find this anywhere so I decided to open a topic about it. I downloaded the Nvidia Video Codec SDK 11.1.5 and then built it successfully with cmake using the release flag as in the read me file. I made sure to install all the necessary prerequisites as per the same pdf, but still there was an error when I ran the make command. Namely ‘AVFormatContext {aka struct AVFormatContext}’ has no member named ‘url’. I went through the documentation of the AVFormat library, as well as the header of my installation and this member was there so the code should’ve been running smoothly. So currently I’m pretty confused as to why this is happening.
I’m currently running Ubuntu 18.04 inside WSL2. I also have an anaconda environment, if that’s relevant. Additionally the nvidia-smi command shows, that the current driver is 510.06 and the output of ffmpeg is as follows:
ffmpeg version 4.1 Copyright (c) 2000-2018 the FFmpeg developers
built with gcc 7.3.0 (crosstool-NG 1.23.0.449-a04d0)
configuration: --prefix=/home/milen/anaconda3/envs/gcn_an_det --cc=/home/conda/feedstock_root/build_artifacts/ffmpeg_1551253354453/_build_env/bin/x86_64-conda_cos6-linux-gnu-cc --disable-doc --disable-openssl --enable-avresample --enable-gnutls --enable-gpl --enable-hardcoded-tables --enable-libfreetype --enable-libopenh264 --enable-libx264 --enable-pic --enable-pthreads --enable-shared --enable-static --enable-version3 --enable-zlib --enable-libmp3lame
libavutil 56. 22.100 / 56. 22.100
libavcodec 58. 35.100 / 58. 35.100
libavformat 58. 20.100 / 58. 20.100
libavdevice 58. 5.100 / 58. 5.100
libavfilter 7. 40.101 / 7. 40.101
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 3.100 / 5. 3.100
libswresample 3. 3.100 / 3. 3.100
libpostproc 55. 3.100 / 55. 3.100
Any help would be appreciated.
EDIT: The file, which creates the problem is FFmpegStreamer.h.
