OpenCV Error:The function/feature is not implemented (The called functionality is disabled for current build or platform) in throw_nogpu,file /hdd/buildbot/slave_jetson_tx_3/35-04T-L4T-R24/opencv/modules/gpu/src/precomp.hppp,line 132 terminate called after throwing an instance of ‘cv::Exception’
what():/hdd/buildbot/slave_jetson_tx_3/35-04T-L4T-R24/opencv/modules/gpu/src/precomp.hpp:132:error(-213)The called functionality is disabled for current build or platform in fuction throw_nogpu
Please move to OpenCV 3.2 or later one with gpu configuration.
OpenCV4Tegra Version 2.4.13 is provided as deprecated in Release 28.1. OpenCV4Tegra
provides CPU and GPU enabled acceleration for OpenCV Version 2.4.13. These
improvements have been integrated into the OpenCV project in version 3.2.
Do you mean opencv2 is can’t be used and must use opencv3? Have you tried it and what is the compile options? Can you provide the link?
I believe openCV4tegra test does not cover all such case and it is going to be deprecated. To get more resources for openCV issue, moving to opencv3 would be a better choice.
