vLLM container 25.10-py3 fails to start
I’m running the Hermes model in the vLLM container. This used to work in version 25.09-py3. But now fails in version 25.10-py3.
The docker command is
vllm:
deploy:
resources:
limits:
memory: 100G
image: nvcr.io/nvidia/vllm:25.10-py3
ports:
- 8000:8000
privileged: true
gpus: all
shm_size: 8gb
ipc: host
ulimits:
memlock: 1
stack: 67108864
env_file:
- .env
volumes:
- $HOME/.cache:/root/.cache
- $PWD:/workspace
entrypoint:
“vllm”, “serve”,
“–gpu-memory-utilization=0.7”,
“–max_model_len=5000”,
“–host=0.0.0.0”, “–port=8000”,
“NousResearch/Hermes-4-70B-FP8”
Some messages in the startup log:
Repeatedly: Trying to use TMA Descriptor Prefetch without CUTE_ARCH_TMA_SM90_ENABLED.
And then torch.AcceleratorError: CUDA error: unspecified launch failure
See the attached file for a full log of the container start
vllm-exception.txt (50.3 KB)
A
Some extra information:
I did delete /root/.cache/vllm/torch_compile_cache/ but the problem persists.
Changing the version back to 25.09-py3 it starts immediately.
We can launch nvcr.io/nvidia/vllm:25.10-py3 without any error.
Could you remove the clear the $HOME/.cache and try it again?
$ sudo docker run -it --rm nvcr.io/nvidia/vllm:25.10-py3
== vLLM ==
NVIDIA Release 25.10 (build 224204848)
vLLM Version 0.10.2+9dd9ca32
Container image Copyright (c) 2025, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Copyright (c) 2014-2024 Facebook Inc.
Copyright (c) 2011-2014 Idiap Research Institute (Ronan Collobert)
Copyright (c) 2012-2014 Deepmind Technologies    (Koray Kavukcuoglu)
Copyright (c) 2011-2012 NEC Laboratories America (Koray Kavukcuoglu)
Copyright (c) 2011-2013 NYU                      (Clement Farabet)
Copyright (c) 2006-2010 NEC Laboratories America (Ronan Collobert, Leon Bottou, Iain Melvin, Jason Weston)
Copyright (c) 2006      Idiap Research Institute (Samy Bengio)
Copyright (c) 2001-2004 Idiap Research Institute (Ronan Collobert, Samy Bengio, Johnny Mariethoz)
Copyright (c) 2015      Google Inc.
Copyright (c) 2015      Yangqing Jia
Copyright (c) 2013-2016 The Caffe contributors
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
GOVERNING TERMS: The software and materials are governed by the NVIDIA Software License Agreement
(found at https://www.nvidia.com/en-us/agreements/enterprise-software/nvidia-software-license-agreement/)
and the Product-Specific Terms for NVIDIA AI Products
(found at https://www.nvidia.com/en-us/agreements/enterprise-software/product-specific-terms-for-ai-products/).
NOTE: The SHMEM allocation limit is set to the default of 64MB.  This may be
   insufficient for vLLM.  NVIDIA recommends the use of the following flags:
   docker run --gpus all --ipc=host --ulimit memlock=-1 --ulimit stack=67108864 ...
root@f1bd4f0d4cf7:/workspace# python3 -m vllm.entrypoints.openai.api_server --model nvidia/Llama-3.1-8B-Instruct-FP8 --trust-remote-code --tensor-parallel-size 1 --max-model-len 1024 --gpu-memory-utilization 0.85
INFO 11-03 03:39:59 [__init__.py:216] Automatically detected platform cuda.
(APIServer pid=157) INFO 11-03 03:40:00 [api_server.py:1919] vLLM API server version 0.10.2+9dd9ca32.nv25.10
(APIServer pid=157) INFO 11-03 03:40:00 [utils.py:328] non-default args: {'model': 'nvidia/Llama-3.1-8B-Instruct-FP8', 'trust_remote_code': True, 'max_model_len': 1024, 'gpu_memory_utilization': 0.85}
(APIServer pid=157) The argument `trust_remote_code` is to be used with Auto classes. It has no effect here and is ignored.
config.json: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████| 879/879 [00:00<00:00, 3.72MB/s]
hf_quant_config.json: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████| 241/241 [00:00<00:00, 1.72MB/s]
(APIServer pid=157) INFO 11-03 03:40:10 [__init__.py:742] Resolved architecture: LlamaForCausalLM
(APIServer pid=157) `torch_dtype` is deprecated! Use `dtype` instead!
(APIServer pid=157) INFO 11-03 03:40:10 [__init__.py:1815] Using max model len 1024
(APIServer pid=157) WARNING 11-03 03:40:11 [_ipex_ops.py:16] Import error msg: No module named 'intel_extension_for_pytorch'
(APIServer pid=157) INFO 11-03 03:40:14 [scheduler.py:222] Chunked prefill is enabled with max_num_batched_tokens=2048.
(APIServer pid=157) WARNING 11-03 03:40:14 [modelopt.py:71] Detected ModelOpt fp8 checkpoint. Please note that the format is experimental and could change.
tokenizer_config.json: 50.9kB [00:00, 44.8MB/s]
tokenizer.json: 9.09MB [00:00, 16.2MB/s]
special_tokens_map.json: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████| 325/325 [00:00<00:00, 1.57MB/s]
generation_config.json: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████| 189/189 [00:00<00:00, 913kB/s]
INFO 11-03 03:40:25 [__init__.py:216] Automatically detected platform cuda.
(EngineCore_DP0 pid=226) INFO 11-03 03:40:27 [core.py:654] Waiting for init message from front-end.
(EngineCore_DP0 pid=226) INFO 11-03 03:40:27 [core.py:76] Initializing a V1 LLM engine (v0.10.2+9dd9ca32.nv25.10) with config: model='nvidia/Llama-3.1-8B-Instruct-FP8', speculative_config=None, tokenizer='nvidia/Llama-3.1-8B-Instruct-FP8', skip_tokenizer_init=False, tokenizer_mode=auto, revision=None, tokenizer_revision=None, trust_remote_code=True, dtype=torch.bfloat16, max_seq_len=1024, download_dir=None, load_format=auto, tensor_parallel_size=1, pipeline_parallel_size=1, data_parallel_size=1, disable_custom_all_reduce=False, quantization=modelopt, enforce_eager=False, kv_cache_dtype=auto, device_config=cuda, decoding_config=DecodingConfig(backend='auto', disable_fallback=False, disable_any_whitespace=False, disable_additional_properties=False, reasoning_backend=''), observability_config=ObservabilityConfig(show_hidden_metrics_for_version=None, otlp_traces_endpoint=None, collect_detailed_traces=None), seed=0, served_model_name=nvidia/Llama-3.1-8B-Instruct-FP8, enable_prefix_caching=True, chunked_prefill_enabled=True, use_async_output_proc=True, pooler_config=None, compilation_config={"level":3,"debug_dump_path":"","cache_dir":"","backend":"","custom_ops":[],"splitting_ops":["vllm.unified_attention","vllm.unified_attention_with_output","vllm.mamba_mixer2","vllm.mamba_mixer","vllm.short_conv","vllm.linear_attention","vllm.plamo2_mamba_mixer","vllm.gdn_attention"],"use_inductor":true,"compile_sizes":[],"inductor_compile_config":{"enable_auto_functionalized_v2":false},"inductor_passes":{},"cudagraph_mode":1,"use_cudagraph":true,"cudagraph_num_of_warmups":1,"cudagraph_capture_sizes":[512,504,496,488,480,472,464,456,448,440,432,424,416,408,400,392,384,376,368,360,352,344,336,328,320,312,304,296,288,280,272,264,256,248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,4,2,1],"cudagraph_copy_inputs":false,"full_cuda_graph":false,"pass_config":{},"max_capture_size":512,"local_cache_dir":null}
[W1103 03:40:45.697080431 ProcessGroupNCCL.cpp:936] Warning: TORCH_NCCL_AVOID_RECORD_STREAMS is the default now, this environment variable is thus deprecated. (function operator())
[Gloo] Rank 0 is connected to 0 peer ranks. Expected number of connected peer ranks is : 0
(EngineCore_DP0 pid=226) INFO 11-03 03:40:45 [parallel_state.py:1165] rank 0 in world size 1 is assigned as DP rank 0, PP rank 0, TP rank 0, EP rank 0
(EngineCore_DP0 pid=226) INFO 11-03 03:40:45 [topk_topp_sampler.py:58] Using FlashInfer for top-p & top-k sampling.
(EngineCore_DP0 pid=226) INFO 11-03 03:40:45 [gpu_model_runner.py:2338] Starting to load model nvidia/Llama-3.1-8B-Instruct-FP8...
(EngineCore_DP0 pid=226) INFO 11-03 03:40:45 [gpu_model_runner.py:2370] Loading model from scratch...
(EngineCore_DP0 pid=226) INFO 11-03 03:40:46 [cuda.py:362] Using Flash Attention backend on V1 engine.
(EngineCore_DP0 pid=226) INFO 11-03 03:40:47 [weight_utils.py:348] Using model weights format ['*.safetensors']
model-00001-of-00002.safetensors: 100%|████████████████████████████████████████████████████████████████████████████████████| 5.00G/5.00G [01:43<00:00, 48.5MB/s]
model-00002-of-00002.safetensors: 100%|████████████████████████████████████████████████████████████████████████████████████| 4.08G/4.08G [01:44<00:00, 39.0MB/s]
(EngineCore_DP0 pid=226) INFO 11-03 03:42:33 [weight_utils.py:369] Time spent downloading weights for nvidia/Llama-3.1-8B-Instruct-FP8: 106.525137 seconds9MB/s]
model.safetensors.index.json: 68.1kB [00:00, 91.1MB/s]
Loading safetensors checkpoint shards:   0% Completed | 0/2 [00:00<?, ?it/s]
Loading safetensors checkpoint shards:  50% Completed | 1/2 [00:00<00:00,  1.03it/s]
Loading safetensors checkpoint shards: 100% Completed | 2/2 [00:01<00:00,  1.19it/s]
Loading safetensors checkpoint shards: 100% Completed | 2/2 [00:01<00:00,  1.16it/s]
(EngineCore_DP0 pid=226) INFO 11-03 03:42:36 [default_loader.py:268] Loading weights took 1.87 seconds
(EngineCore_DP0 pid=226) INFO 11-03 03:42:37 [gpu_model_runner.py:2392] Model loading took 8.4890 GiB and 110.664644 seconds
(EngineCore_DP0 pid=226) INFO 11-03 03:42:43 [backends.py:539] Using cache directory: /root/.cache/vllm/torch_compile_cache/d77cdd90d8/rank_0_0/backbone for vLLM's torch.compile
(EngineCore_DP0 pid=226) INFO 11-03 03:42:43 [backends.py:550] Dynamo bytecode transform time: 6.49 s
(EngineCore_DP0 pid=226) INFO 11-03 03:42:50 [backends.py:194] Cache the graph for dynamic shape for later use
(EngineCore_DP0 pid=226) INFO 11-03 03:43:01 [backends.py:215] Compiling a graph for dynamic shape takes 17.14 s
(EngineCore_DP0 pid=226) INFO 11-03 03:44:41 [monitor.py:34] torch.compile takes 23.63 s in total
(EngineCore_DP0 pid=226) INFO 11-03 03:45:39 [gpu_worker.py:298] Available KV cache memory: 92.80 GiB
(EngineCore_DP0 pid=226) INFO 11-03 03:45:40 [kv_cache_utils.py:864] GPU KV cache size: 760,176 tokens
(EngineCore_DP0 pid=226) INFO 11-03 03:45:40 [kv_cache_utils.py:868] Maximum concurrency for 1,024 tokens per request: 742.36x
(EngineCore_DP0 pid=226) 2025-11-03 03:45:46,113 - INFO - autotuner.py:256 - flashinfer.jit: [Autotuner]: Autotuning process starts ...
(EngineCore_DP0 pid=226) 2025-11-03 03:46:02,546 - INFO - autotuner.py:262 - flashinfer.jit: [Autotuner]: Autotuning process ends
Capturing CUDA graphs (mixed prefill-decode, PIECEWISE): 100%|██████████████████████████████████████████████████████████████████| 67/67 [00:05<00:00, 12.31it/s]
(EngineCore_DP0 pid=226) INFO 11-03 03:46:08 [gpu_model_runner.py:3118] Graph capturing finished in 6 secs, took 0.75 GiB
(EngineCore_DP0 pid=226) INFO 11-03 03:46:08 [gpu_worker.py:391] Free memory on device (116.73/122.82 GiB) on startup. Desired GPU memory utilization is (0.85, 104.4 GiB). Actual usage is 8.49 GiB for weight, 1.02 GiB for peak activation, 2.1 GiB for non-torch memory, and 0.75 GiB for CUDAGraph memory. Replace gpu_memory_utilization config with `--kv-cache-memory=98679709388` to fit into requested memory, or `--kv-cache-memory=111919078912` to fully utilize gpu memory. Current kv cache memory in use is 99638353612 bytes.
(EngineCore_DP0 pid=226) INFO 11-03 03:46:09 [core.py:218] init engine (profile, create kv cache, warmup model) took 211.92 seconds
(APIServer pid=157) INFO 11-03 03:46:10 [loggers.py:142] Engine 000: vllm cache_config_info with initialization after num_gpu_blocks is: 47511
(APIServer pid=157) INFO 11-03 03:46:10 [async_llm.py:180] Torch profiler disabled. AsyncLLM CPU traces will not be collected.
(APIServer pid=157) INFO 11-03 03:46:11 [api_server.py:1715] Supported_tasks: ['generate']
(APIServer pid=157) WARNING 11-03 03:46:11 [__init__.py:1695] Default sampling parameters have been overridden by the model's Hugging Face generation config recommended from the model creator. If this is not intended, please relaunch vLLM instance with `--generation-config vllm`.
(APIServer pid=157) INFO 11-03 03:46:11 [serving_responses.py:130] Using default chat sampling params from model: {'temperature': 0.6, 'top_p': 0.9}
(APIServer pid=157) INFO 11-03 03:46:12 [serving_chat.py:137] Using default chat sampling params from model: {'temperature': 0.6, 'top_p': 0.9}
(APIServer pid=157) INFO 11-03 03:46:12 [serving_completion.py:76] Using default completion sampling params from model: {'temperature': 0.6, 'top_p': 0.9}
(APIServer pid=157) INFO 11-03 03:46:12 [api_server.py:1994] Starting vLLM API server 0 on http://0.0.0.0:8000
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:36] Available routes are:
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /openapi.json, Methods: GET, HEAD
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /docs, Methods: GET, HEAD
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /docs/oauth2-redirect, Methods: GET, HEAD
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /redoc, Methods: GET, HEAD
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /health, Methods: GET
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /load, Methods: GET
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /ping, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /ping, Methods: GET
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /tokenize, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /detokenize, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/models, Methods: GET
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /version, Methods: GET
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/responses, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/responses/{response_id}, Methods: GET
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/responses/{response_id}/cancel, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/chat/completions, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/completions, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/embeddings, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /pooling, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /classify, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /score, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/score, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/audio/transcriptions, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/audio/translations, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /rerank, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v1/rerank, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /v2/rerank, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /scale_elastic_ep, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /is_scaling_elastic_ep, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /invocations, Methods: POST
(APIServer pid=157) INFO 11-03 03:46:12 [launcher.py:44] Route: /metrics, Methods: GET
(APIServer pid=157) INFO:     Started server process [157]
(APIServer pid=157) INFO:     Waiting for application startup.
(APIServer pid=157) INFO:     Application startup complete.
@AastaLLL I notice that you tested with another model. Maybe the issue is specifically with that (type of) model? I myself don’t have the problem with another model.
Can you test with that model?
I did try again with a completely empty $HOME/.cache
Of course It took a long time to download the model again.
Btrw I was surprised there was no download progress indication after the line Using model weights format ['*.safetensors']
Even though I noticed the network traffic and the huggingface cache directory being updated.
It looks like the same error. I’ll upload log file today when I get at the Jetson Thor.
Yes, same error with a new $Home/.cache directory. See attachment.
When I switch back to 25.09-py3 it does start without errors. So I do think there’s an issue.
Can you test with that same Hermes model?
vllm-exception-2.txt (50.6 KB)
Yes, we are testing the model internally.
Will update the status from our side later.
We didn’t meet the issue with NousResearch/Hermes-4-70B-FP8.
Is it possible that the issue is related to the APIs?
Would you mind giving our command a try?
root@f0d13212f3c1:/workspace# python -m vllm.entrypoints.openai.api_server \
  --host 0.0.0.0 \
  --port 6678 \
  --tensor-parallel-size 1 \
  --gpu-memory-utilization 0.85 \
  --max-model-len 32k \
  --cuda-graph-sizes 4 \
  --max_num_seqs 4 \
  --served-model-name NousResearch/Hermes-4-70B-FP8
INFO 11-06 09:51:01 [__init__.py:216] Automatically detected platform cuda.
(APIServer pid=157) INFO 11-06 09:51:02 [api_server.py:1919] vLLM API server version 0.10.2+9dd9ca32.nv25.10
(APIServer pid=157) INFO 11-06 09:51:02 [utils.py:328] non-default args: {'host': '0.0.0.0', 'port': 6678, 'max_model_len': 32000, 'served_model_name': ['NousResearch/Hermes-4-70B-FP8'], 'gpu_memory_utilization': 0.85, 'max_num_seqs': 4, 'cuda_graph_sizes': [4]}
config.json: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 726/726 [00:00<00:00, 6.20MB/s]
(APIServer pid=157) INFO 11-06 09:51:10 [__init__.py:742] Resolved architecture: Qwen3ForCausalLM
(APIServer pid=157) INFO 11-06 09:51:10 [__init__.py:1815] Using max model len 32000
(APIServer pid=157) INFO 11-06 09:51:12 [scheduler.py:222] Chunked prefill is enabled with max_num_batched_tokens=2048.
tokenizer_config.json: 9.73kB [00:00, 20.8MB/s]
vocab.json: 2.78MB [00:00, 7.99MB/s]
merges.txt: 1.67MB [00:00, 25.8MB/s]
tokenizer.json: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████| 11.4M/11.4M [00:01<00:00, 6.71MB/s]
generation_config.json: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████| 239/239 [00:00<00:00, 1.68MB/s]
INFO 11-06 09:51:26 [__init__.py:216] Automatically detected platform cuda.
(EngineCore_DP0 pid=244) INFO 11-06 09:51:27 [core.py:654] Waiting for init message from front-end.
(EngineCore_DP0 pid=244) INFO 11-06 09:51:27 [core.py:76] Initializing a V1 LLM engine (v0.10.2+9dd9ca32.nv25.10) with config: model='Qwen/Qwen3-0.6B', speculative_config=None, tokenizer='Qwen/Qwen3-0.6B', skip_tokenizer_init=False, tokenizer_mode=auto, revision=None, tokenizer_revision=None, trust_remote_code=False, dtype=torch.bfloat16, max_seq_len=32000, download_dir=None, load_format=auto, tensor_parallel_size=1, pipeline_parallel_size=1, data_parallel_size=1, disable_custom_all_reduce=False, quantization=None, enforce_eager=False, kv_cache_dtype=auto, device_config=cuda, decoding_config=DecodingConfig(backend='auto', disable_fallback=False, disable_any_whitespace=False, disable_additional_properties=False, reasoning_backend=''), observability_config=ObservabilityConfig(show_hidden_metrics_for_version=None, otlp_traces_endpoint=None, collect_detailed_traces=None), seed=0, served_model_name=NousResearch/Hermes-4-70B-FP8, enable_prefix_caching=True, chunked_prefill_enabled=True, use_async_output_proc=True, pooler_config=None, compilation_config={"level":3,"debug_dump_path":"","cache_dir":"","backend":"","custom_ops":[],"splitting_ops":["vllm.unified_attention","vllm.unified_attention_with_output","vllm.mamba_mixer2","vllm.mamba_mixer","vllm.short_conv","vllm.linear_attention","vllm.plamo2_mamba_mixer","vllm.gdn_attention"],"use_inductor":true,"compile_sizes":[],"inductor_compile_config":{"enable_auto_functionalized_v2":false},"inductor_passes":{},"cudagraph_mode":1,"use_cudagraph":true,"cudagraph_num_of_warmups":1,"cudagraph_capture_sizes":[4,2,1],"cudagraph_copy_inputs":false,"full_cuda_graph":false,"pass_config":{},"max_capture_size":4,"local_cache_dir":null}
[W1106 09:51:51.364940700 ProcessGroupNCCL.cpp:936] Warning: TORCH_NCCL_AVOID_RECORD_STREAMS is the default now, this environment variable is thus deprecated. (function operator())
(EngineCore_DP0 pid=244) INFO 11-06 09:51:51 [parallel_state.py:1165] rank 0 in world size 1 is assigned as DP rank 0, PP rank 0, TP rank 0, EP rank 0
(EngineCore_DP0 pid=244) INFO 11-06 09:51:51 [topk_topp_sampler.py:58] Using FlashInfer for top-p & top-k sampling.
(EngineCore_DP0 pid=244) INFO 11-06 09:51:51 [gpu_model_runner.py:2338] Starting to load model Qwen/Qwen3-0.6B...
(EngineCore_DP0 pid=244) INFO 11-06 09:51:51 [gpu_model_runner.py:2370] Loading model from scratch...
(EngineCore_DP0 pid=244) INFO 11-06 09:51:51 [cuda.py:362] Using Flash Attention backend on V1 engine.
(EngineCore_DP0 pid=244) INFO 11-06 09:51:52 [weight_utils.py:348] Using model weights format ['*.safetensors']
model.safetensors: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████| 1.50G/1.50G [00:16<00:00, 91.4MB/s]
(EngineCore_DP0 pid=244) INFO 11-06 09:52:09 [weight_utils.py:369] Time spent downloading weights for Qwen/Qwen3-0.6B: 17.446960 seconds
(EngineCore_DP0 pid=244) INFO 11-06 09:52:10 [weight_utils.py:406] No model.safetensors.index.json found in remote.
Loading safetensors checkpoint shards:   0% Completed | 0/1 [00:00<?, ?it/s]
Loading safetensors checkpoint shards: 100% Completed | 1/1 [00:02<00:00,  2.20s/it]
(EngineCore_DP0 pid=244) INFO 11-06 09:52:12 [default_loader.py:268] Loading weights took 2.23 seconds
(EngineCore_DP0 pid=244) INFO 11-06 09:52:12 [gpu_model_runner.py:2392] Model loading took 1.1201 GiB and 20.854677 seconds
(EngineCore_DP0 pid=244) INFO 11-06 09:52:17 [backends.py:539] Using cache directory: /root/.cache/vllm/torch_compile_cache/715e679d97/rank_0_0/backbone for vLLM's torch.compile
(EngineCore_DP0 pid=244) INFO 11-06 09:52:17 [backends.py:550] Dynamo bytecode transform time: 4.60 s
(EngineCore_DP0 pid=244) [rank0]:W1106 09:52:18.696000 244 torch/_inductor/utils.py:1554] [0/0] Not enough SMs to use max_autotune_gemm mode
(EngineCore_DP0 pid=244) INFO 11-06 09:52:23 [backends.py:194] Cache the graph for dynamic shape for later use
(EngineCore_DP0 pid=244) INFO 11-06 09:52:37 [backends.py:215] Compiling a graph for dynamic shape takes 19.53 s
(EngineCore_DP0 pid=244) INFO 11-06 09:52:40 [monitor.py:34] torch.compile takes 24.13 s in total
(EngineCore_DP0 pid=244) INFO 11-06 09:53:39 [gpu_worker.py:298] Available KV cache memory: 101.12 GiB
(EngineCore_DP0 pid=244) INFO 11-06 09:53:39 [kv_cache_utils.py:864] GPU KV cache size: 946,752 tokens
(EngineCore_DP0 pid=244) INFO 11-06 09:53:39 [kv_cache_utils.py:868] Maximum concurrency for 32,000 tokens per request: 29.59x
(EngineCore_DP0 pid=244) 2025-11-06 09:53:42,231 - INFO - autotuner.py:256 - flashinfer.jit: [Autotuner]: Autotuning process starts ...
(EngineCore_DP0 pid=244) 2025-11-06 09:53:42,284 - INFO - autotuner.py:262 - flashinfer.jit: [Autotuner]: Autotuning process ends
Capturing CUDA graphs (mixed prefill-decode, PIECEWISE): 100%|███████████████████████████████████████████████████████████████████████| 3/3 [00:00<00:00, 22.59it/s]
(EngineCore_DP0 pid=244) INFO 11-06 09:53:43 [gpu_model_runner.py:3118] Graph capturing finished in 1 secs, took 0.19 GiB
(EngineCore_DP0 pid=244) INFO 11-06 09:53:43 [gpu_worker.py:391] Free memory on device (117.92/122.82 GiB) on startup. Desired GPU memory utilization is (0.85, 104.4 GiB). Actual usage is 1.12 GiB for weight, 0.3 GiB for peak activation, 1.86 GiB for non-torch memory, and 0.19 GiB for CUDAGraph memory. Replace gpu_memory_utilization config with `--kv-cache-memory=108218533273` to fit into requested memory, or `--kv-cache-memory=122736089088` to fully utilize gpu memory. Current kv cache memory in use is 108582073753 bytes.
(EngineCore_DP0 pid=244) INFO 11-06 09:53:43 [core.py:218] init engine (profile, create kv cache, warmup model) took 90.43 seconds
(APIServer pid=157) INFO 11-06 09:53:44 [loggers.py:142] Engine 000: vllm cache_config_info with initialization after num_gpu_blocks is: 59172
(APIServer pid=157) INFO 11-06 09:53:44 [async_llm.py:180] Torch profiler disabled. AsyncLLM CPU traces will not be collected.
(APIServer pid=157) INFO 11-06 09:53:45 [api_server.py:1715] Supported_tasks: ['generate']
(APIServer pid=157) WARNING 11-06 09:53:45 [__init__.py:1695] Default sampling parameters have been overridden by the model's Hugging Face generation config recommended from the model creator. If this is not intended, please relaunch vLLM instance with `--generation-config vllm`.
(APIServer pid=157) INFO 11-06 09:53:45 [serving_responses.py:130] Using default chat sampling params from model: {'temperature': 0.6, 'top_k': 20, 'top_p': 0.95}
(APIServer pid=157) INFO 11-06 09:53:46 [serving_chat.py:137] Using default chat sampling params from model: {'temperature': 0.6, 'top_k': 20, 'top_p': 0.95}
(APIServer pid=157) INFO 11-06 09:53:46 [serving_completion.py:76] Using default completion sampling params from model: {'temperature': 0.6, 'top_k': 20, 'top_p': 0.95}
(APIServer pid=157) INFO 11-06 09:53:46 [api_server.py:1994] Starting vLLM API server 0 on http://0.0.0.0:6678
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:36] Available routes are:
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /openapi.json, Methods: HEAD, GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /docs, Methods: HEAD, GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /docs/oauth2-redirect, Methods: HEAD, GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /redoc, Methods: HEAD, GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /health, Methods: GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /load, Methods: GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /ping, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /ping, Methods: GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /tokenize, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /detokenize, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/models, Methods: GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /version, Methods: GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/responses, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/responses/{response_id}, Methods: GET
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/responses/{response_id}/cancel, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/chat/completions, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/completions, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/embeddings, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /pooling, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /classify, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /score, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/score, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/audio/transcriptions, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/audio/translations, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /rerank, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v1/rerank, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /v2/rerank, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /scale_elastic_ep, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /is_scaling_elastic_ep, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /invocations, Methods: POST
(APIServer pid=157) INFO 11-06 09:53:46 [launcher.py:44] Route: /metrics, Methods: GET
I will.
Which docker command did you use? sudo docker run -it --rm ``nvcr.io/nvidia/vllm:25.10-py3 ?
@AastaLLL when I look at the your log I notice that it says Starting to load model Qwen/Qwen3-0.6B... and that there is 1 safetensor checkpoint shard. And Model loading took 1.1201 GiB and 20.854677 secondsWhich is much smaller than I’d expect for a 70B model.
When I run the Hermes model using vllm 20.09-py3 I see a log message Starting to load model NousResearch/Hermes-4-70B-FP8… and there are 15 checkpoint shards. And Model loading took 67.7231 GiB and 28.921133 secondsWhich is as expected from a 70B model.
Looking at the documentation I see that the default model is indeed Qwen/Qwen3-0.6B. And that --served-model-name just configures what it should call itself in the openai API.
Can you test again with --model NousResearch/Hermes-4-70B-FP8 instead of --served-model-name NousResearch/Hermes-4-70B-FP8 ?
Thanks for pointing this out. Didn’t notice that when we tested it.
We are testing this again with --model NousResearch/Hermes-4-70B-FP8 and will update more information with you soon.
Thanks for your patience.
Confirmed that we can see the same error with Hermes-4-70B-FP8 on vllm 25.10 container.
We are checking with the internal team to gather more information.
Could you test the same model with our recent 25.11 release?
Thank you for the follow up. Unfortunately same problem with 25.11-py3
Thanks for the update.
We will check with the internal team and update.
