VPI Python Import Error
Hi everyone,
I am currently trying to get the stereo disparity estimator in the VPI to work with Python but there is a problem with the import section. No module error is thrown. When currently installed modules are checked, VPI is not on the list.
import vpi
Gives “no module named vpi” error. I can’t import VPI using Python 3.7.1. Python 2.7 also gives the same error.
However, i think the VPI 1.1 is installed on the system because when I check with
apt show cache nvidia-vpi
The log result is below
Package: nvidia-vpi
Version: 4.5.1-b17
Priority: standard
Section: metapackages
Maintainer: NVIDIA Corporation
Installed-Size: 199 kB
Depends: libnvvpi1 (= 1.0.15), vpi1-dev (= 1.0.15), vpi1-samples (= 1.0.15), vpi1-demos (= 1.0.15)
Homepage: http://developer.nvidia.com/jetson
Download-Size: 29,3 kB
APT-Manual-Installed: yes
APT-Sources: https://repo.download.nvidia.com/jetson/t210 r32.5/main arm64 Packages
Description: NVIDIA Vpi Meta Package
N: Unable to locate package cache
N: There is 1 additional record. Please use the '-a' switch to see it
I can also run the VPI Remap demo with the “VPI Demos V1.0” on the desktop. It opens a folder with a single demo in it. It is the “VPI Remap Demo 1.0”. When I run it, it connects to my camera and 4 video streams with different transformations (mirror, pinch, whirl, waves) run simultaneously on CUDA.
Jetson Nano 4GB
Ubuntu 18.04.6 LTS
Any help would be appreciated, Thanks
Please noted that VPI is compiled with the default python version, which should be version 3.6.
Would you mind importing it with python 3.6 to see if it works?
Hi, thank you for answering. I currently have multiple python installations on my system. One of them is Python 3.6.9.
I don’t know if it should be exactly Python 3.6.0 but it again gave “no module named vpi” error.
Code i tried:
import sys
print(sys.version)
import vpi
Output:
3.6.9 (default, Jan 26 2021, 15:33:00)
[GCC 8.4.0]
  File "/home/cezeri/Gimbal/VPI_import_test.py", line 5, in <module>
    import vpi
ModuleNotFoundError: No module named 'vpi'
I believe the problem is something about the packages because I don’t have any packages for python-vpi connection.
Index, In this link there are many packages for Jetpack versions.
There are some packages that look like python-vpi stuff. I believe non them of are installed on my system.
For example:
  • python-vpi1_1.2.3_arm64.deb
  • python-vpi1_1.1.12_arm64.deb
  • python-vpi1_1.1.15_arm64.deb
Just searching for “python-vpi” string with CTRL+F in that web page shows many packages like those.
My Jetpack version might not be suitable with these packages because there is no such package under Jetpack 4.5.
When I run dpkg -l | grep vpi command the output says
dpkg -l | grep vpi
ii  libnvvpi1                                     1.0.15                                     arm64        NVIDIA Vision Programming Interface library
ii  nvidia-vpi                                    4.5.1-b17                                  arm64        NVIDIA Vpi Meta Package
ii  vpi1-demos                                    1.0.15                                     arm64        NVIDIA VPI GUI demo applications
ii  vpi1-dev                                      1.0.15                                     arm64        NVIDIA VPI C/C++ development library and headers
ii  vpi1-samples                                  1.0.15                                     arm64        NVIDIA VPI command-line sample applications```
Re-installing the whole system and os with Jetpack 4.6 fixed it
