Vulnerabilities related to Jetson Orin Nano
The following product security page lists vulnerabilities in NVIDIA products.
I am only interested in vulnerability information related to the Jetson ORIN Nano,
but I would like to know how to determine which of the listed vulnerabilities are related to the Jetson ORIN Nano.
Is it sufficient to check only titles that contain the word “Jetson,”
or do I also need to examine the details of titles that do not contain the word “Jetson”?
To determine which vulnerabilities are related to the Jetson ORIN Nano, it’s not sufficient to only check titles that contain the word “Jetson.” You should also examine the details of titles that do not contain the word “Jetson” as they may still be relevant to the Jetson ORIN Nano.
Here’s a step-by-step approach to help you identify vulnerabilities related to the Jetson ORIN Nano:
  1. Search for titles containing “Jetson ORIN Nano” or “Jetson ORIN”: Start by searching for titles that explicitly mention “Jetson ORIN Nano” or “Jetson ORIN.” These are likely to be directly related to the Jetson ORIN Nano.
  2. Check titles containing “Jetson”: Expand your search to include titles that contain the word “Jetson” but may not specifically mention “ORIN Nano.” These could still be relevant to the Jetson ORIN Nano, especially if they mention other Jetson models or the Jetson platform in general.
  3. Examine titles related to NVIDIA products: Even if a title doesn’t contain the word “Jetson,” it may still be relevant to the Jetson ORIN Nano if it mentions other NVIDIA products that share similar components or software. For example, vulnerabilities affecting NVIDIA’s Tegra or Linux-based products could potentially impact the Jetson ORIN Nano.
  4. Read the vulnerability details: Once you’ve identified a potentially relevant title, read the details of the vulnerability to determine if it affects the Jetson ORIN Nano. Look for information about the affected products, versions, and components.
  5. Check the affected products and versions: Verify that the vulnerability affects the Jetson ORIN Nano or a related product. Check the versions of the affected products to ensure that the vulnerability is relevant to your specific use case.
  6. Consult the NVIDIA Product Security page: If you’re still unsure about the relevance of a vulnerability, consult the NVIDIA Product Security page for more information. NVIDIA may provide additional guidance or clarification on the affected products and versions.
By following these steps, you can comprehensively identify vulnerabilities related to the Jetson ORIN Nano and ensure that you’re aware of any potential security risks.
Yes, that should be enough.
