I tried to understand the code of aneurysm.py. However, there is one issue which I cannot understand. What is the meaning of "normal_dot_vel": 2.540? The detailed code is below.
I think this code refers to the boundary condition of the outlet region and normal_dot_vel represents the volume flow. Is this correct? However, I cannot understand how the flow rate value of 2.540 is calculated.
If someone has knowledge of this code, please provide information. Thank you for your cooperation.
Shusaku
Integral Continuity 1
integral_continuity = IntegralBoundaryConstraint(
nodes=nodes,
geometry=outlet_mesh,
outvar={"normal_dot_vel": 2.540},
batch_size=1,
integral_batch_size=cfg.batch_size.integral_continuity,
lambda_weighting={"normal_dot_vel": 0.1},
domain.add_constraint(integral_continuity, "integral_continuity_1")
Hi Shusaku,
yes, you are right. The normal_dot_vel represents the volumetric flow rate.
Volumetric flow rate is calculated with inlet area and the mean velocity at the inlet:
vfr = inlet_area * mean_inlet_vel
With a velocity magnitude of the parabolic velocity profile at the inlet: inlet_vel = 1.5 you can approximate the mean velocity with: mean_inlet_vel = 0.5 * inlet_vel
The scaled inlet area is: inlet_area = 21.1284 * (0.4**2)
This results in: vfr = 2.54
I hope this helps.
Best Daniel
Thank you for your valuable advice, Daniel.
That makes sense! I have one more question.
The variable normal_dot_vel has both positive and negative values. What does a negative value signify?
nodes=nodes,
batch_size=1,
# Integral Continuity 2
nodes=nodes,
geometry=integral_mesh,
outvar={"normal_dot_vel": -2.540},
batch_size=1,
The sign indicates the direction of the flow through the surface (inward or outward) and is determined by the orientation of the surface.
