• Hardware Platform (GPU) • DeepStream Version 6.0 • TensorRT Version 8.0.1 • NVIDIA GPU Driver Version (valid for GPU only) 495.44 • Issue Type( questions, bugs)
I have onnx model export with dynamic batch size. it ok when export to tensorRT directly by nvinfer plugin.
I got this log warning Cuda failure: status=1 in cuResData at line 348 from application when using engine have batch size > 1 and setup batch size streammux > 1. The program run ok but the logging and large resource be used.
Hi @trild-vietnam ,
I think “Cuda failure: status=1 in cuResData at line 348” is from your code, right? If it’s, it indicates there is bug in your code.
