T4
• DeepStream Version
5.0
NA
• TensorRT Version
7.0.0.11
440.64.00
I am using deepstream_test1.py. I am using my own NN. It is a simple variant of Resnet created in pytorch using the below code
model = resnet18(pretrained=True)
model.fc = torch.nn.Linear(512, 4)
model = torch.nn.Sequential(model, torch.nn.Softmax(1))
Then I converted it to TRT format using torch2trt, saved it as an engine file, used it in deepstream_test1.py with a customer classifier parser function. Everything is going good for batch-size=1. But if I increase the batch-size to 8 in the nvinfer config file, I see the errors below. Is there something different I need to do when converting the pytorch model using torch2trt? I checked other tickets and did not find any solution.
0:00:03.041280073 1427 0x3425c10 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1647> [UID = 1]: Backend has maxBatchSize 1 whereas 8 has been requested
0:00:03.041308098 1427 0x3425c10 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1818> [UID = 1]: deserialized backend context :/opt/nvidia/deepstream/deepstream-5.0/samples/models/pytorch-resnet-to-trt.engine failed to match config params, trying rebuild
0:00:03.044811811 1427 0x3425c10 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1720> [UID = 1]: Trying to create engine from model files
ERROR: failed to build network since there is no model file matched.
ERROR: failed to build network.
0:00:03.045126259 1427 0x3425c10 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1740> [UID = 1]: build engine file failed
0:00:03.045162610 1427 0x3425c10 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1826> [UID = 1]: build backend context failed
0:00:03.045184524 1427 0x3425c10 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1153> [UID = 1]: generate backend failed, check config file settings
0:00:03.045424731 1427 0x3425c10 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:03.045442242 1427 0x3425c10 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Config file path: 1.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
