Warning: gst-core-error-quark: A lot of buffers are being dropped. (13)
• Hardware Platform (Jetson / GPU) Jetson Xavier NX
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) R32 Revision: 5.0 GCID: 25531747 Board: t186ref
• TensorRT Version 7.1.3 + CUDA 10.2
• Issue Type( questions, new requirements, bugs) Warning: gst-core-error-quark: A lot of buffers are being dropped. (13): gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstEglGlesSink:nvvideo-renderer: There may be a timestamping problem, or this computer is too slow
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) please see below
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) please see below
Hi Deepstream team,
I am not sure if I should attach my code or just ask this to troubleshoot, so before I did, I wanted to ask first.
Would there be a common reason why this error would show up?
I am running this example (Creating a Real-Time License Plate Detection and Recognition App | NVIDIA Technical Blog) in Python with some additional code I am running.
Yes. The reason is that the loading is heavy and performance is poor so the pipeline has to drop frames to get itself running.
@Fiona.Chen
Thanks for the quick response.
Is there a way to fix this then? Am i doing too much on each frame which causes this issue?
As I mentioned - I am running this example (Creating a Real-Time License Plate Detection and Recognition App | NVIDIA Developer Blog) in Python.
Would you need some more information to find what might be causing the issue and how to fix it?
The original app is in c/c++, There is already performance data in the page. (Creating a Real-Time License Plate Detection and Recognition App | NVIDIA Developer Blog.
We don’t know how you run it with python, but python is less efficient than c/c++ in general.
