So I go it to run but no data is sent to was IoT core
./deepstream-test5-app -c configs/test5_config_file_src_infer_aws.tx
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine open error
0:00:06.955434445 4094 0x55855418f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed
0:00:06.956589055 4094 0x55855418f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed, try rebuild
0:00:06.956637702 4094 0x55855418f0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
[CWARNING: [TRT]: Tactic Device request: 171MB Available: 157MB. Device memory is insufficient to use tactic.
WARNING: [TRT]: Skipping tactic 2 due to insuficient memory on requested size of 171 detected for tactic 2.
CERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_fp16.engine opened error
0:02:19.699148684 4094 0x55855418f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1942> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:02:19.922661874 4094 0x55855418f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
Sun Aug 27 15:02:37 2023
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:194>: Pipeline ready
(deepstream-test5-app:4094): GStreamer-WARNING **: 15:02:38.892: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(deepstream-test5-app:4094): GStreamer-WARNING **: 15:02:38.913: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(deepstream-test5-app:4094): GStreamer-WARNING **: 15:02:38.933: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(deepstream-test5-app:4094): GStreamer-WARNING **: 15:02:38.953: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(deepstream-test5-app:4094): GStreamer-WARNING **: 15:02:38.973: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(deepstream-test5-app:4094): GStreamer-WARNING **: 15:02:38.993: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(deepstream-test5-app:4094): GStreamer-WARNING **: 15:02:39.013: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(deepstream-test5-app:4094): GStreamer-WARNING **: 15:02:39.033: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:180>: Pipeline running
Sun Aug 27 15:02:42 2023
Sun Aug 27 15:02:47 2023
^[[D^[[C**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
Sun Aug 27 15:02:52 2023
Sun Aug 27 15:02:57 2023
Sun Aug 27 15:03:02 2023
Sun Aug 27 15:03:07 2023
Sun Aug 27 15:03:12 2023
Sun Aug 27 15:03:17 2023
Sun Aug 27 15:03:22 2023
Sun Aug 27 15:03:27 2023
Sun Aug 27 15:03:32 2023
Sun Aug 27 15:03:37 2023
Sun Aug 27 15:03:42 2023
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.24 (0.22)
WARNING; playback mode used with URI [file:///opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/streams/sample_1080p_h264.mp4] not conforming to timestamp format; check README; using system-time
^[[D^[[C
WARNING from sink_sub_bin_sink1: A lot of buffers are being dropped.
Debug info: gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstFakeSink:sink_sub_bin_sink1:
There may be a timestamping problem, or this computer is too slow.
Sun Aug 27 15:03:47 2023
**PERF: 4.79 (4.76) 5.15 (5.12) 5.15 (5.12) 5.00 (2.93)
Sun Aug 27 15:03:52 2023
**PERF: 5.91 (5.26) 5.77 (5.46) 5.77 (5.46) 5.80 (3.77)
Sun Aug 27 15:03:57 2023
**PERF: 4.92 (5.05) 4.99 (5.24) 4.99 (5.24) 4.84 (4.14)
Sun Aug 27 15:04:02 2023
**PERF: 4.57 (4.99) 4.24 (5.03) 4.24 (5.03) 4.94 (4.15)
Sun Aug 27 15:04:07 2023
**PERF: 4.24 (4.87) 5.02 (4.94) 4.96 (4.94) 4.40 (4.29)
Sun Aug 27 15:04:12 2023
**PERF: 5.01 (4.89) 4.64 (4.85) 4.57 (4.85) 4.75 (4.34)
Sun Aug 27 15:04:17 2023
**PERF: 4.74 (4.85) 4.25 (4.84) 4.56 (4.79) 4.69 (4.35)
Sun Aug 27 15:04:22 2023
**PERF: 4.44 (4.77) 4.93 (4.84) 4.39 (4.81) 3.99 (4.35)
Sun Aug 27 15:04:27 2023
**PERF: 4.30 (4.69) 4.33 (4.74) 4.40 (4.74) 4.40 (4.36)
Sun Aug 27 15:04:32 2023
**PERF: 4.29 (4.66) 4.29 (4.71) 4.26 (4.71) 4.00 (4.32)
Sun Aug 27 15:04:37 2023
**PERF: 4.49 (4.67) 4.51 (4.72) 4.33 (4.68) 5.14 (4.35)
^[[D^[[C
Sun Aug 27 15:04:42 2023
**PERF: 4.51 (4.65) 4.37 (4.69) 4.91 (4.66) 4.67 (4.40)
Sun Aug 27 15:04:47 2023
**PERF: 4.41 (4.64) 4.63 (4.68) 4.35 (4.67) 4.05 (4.38)
Sun Aug 27 15:04:52 2023
**PERF: 4.67 (4.64) 4.61 (4.68) 4.41 (4.65) 5.09 (4.38)
Sun Aug 27 15:04:57 2023
**PERF: 4.51 (4.61) 4.51 (4.65) 4.78 (4.65) 4.08 (4.40)
Sun Aug 27 15:05:02 2023
**PERF: 4.43 (4.60) 4.33 (4.63) 4.34 (4.63) 4.42 (4.40)
Sun Aug 27 15:05:07 2023
**PERF: 4.07 (4.57) 3.98 (4.61) 4.09 (4.61) 4.68 (4.36)
Sun Aug 27 15:05:12 2023
**PERF: 4.01 (4.55) 3.68 (4.55) 3.63 (4.55) 3.86 (4.36)
Sun Aug 27 15:05:17 2023
**PERF: 3.70 (4.50) 4.13 (4.53) 3.99 (4.52) 3.90 (4.32)
Sun Aug 27 15:05:22 2023
**PERF: 3.98 (4.49) 3.36 (4.47) 4.05 (4.46) 3.88 (4.31)
Sun Aug 27 15:05:27 2023
**PERF: 3.31 (4.44) 4.34 (4.45) 3.85 (4.45) 3.83 (4.31)
Sun Aug 27 15:05:32 2023
**PERF: 4.62 (4.41) 4.12 (4.43) 3.95 (4.43) 3.78 (4.29)
^[[D^[[C
Sun Aug 27 15:05:37 2023
**PERF: 3.90 (4.41) 3.95 (4.43) 3.59 (4.40) 3.93 (4.26)
Sun Aug 27 15:05:42 2023
**PERF: 3.87 (4.37) 3.82 (4.39) 4.22 (4.39) 3.86 (4.25)
Sun Aug 27 15:05:47 2023
**PERF: 3.73 (4.34) 3.73 (4.36) 3.68 (4.36) 3.62 (4.23)
Sun Aug 27 15:05:52 2023
**PERF: 4.16 (4.35) 4.16 (4.36) 3.95 (4.35) 4.50 (4.21)
Sun Aug 27 15:05:57 2023
**PERF: 3.88 (4.34) 3.66 (4.34) 4.11 (4.32) 3.81 (4.21)
Sun Aug 27 15:06:02 2023
**PERF: 3.72 (4.32) 4.41 (4.32) 4.12 (4.32) 4.22 (4.22)
Sun Aug 27 15:06:07 2023
**PERF: 4.38 (4.31) 4.01 (4.33) 4.11 (4.33) 3.81 (4.19)
Sun Aug 27 15:06:12 2023
**PERF: 3.94 (4.31) 3.66 (4.31) 3.42 (4.30) 4.07 (4.19)
Sun Aug 27 15:06:17 2023
**PERF: 3.96 (4.30) 3.62 (4.29) 4.47 (4.27) 4.02 (4.19)
Sun Aug 27 15:06:22 2023
**PERF: 4.01 (4.28) 4.60 (4.30) 3.66 (4.28) 3.83 (4.17)
Sun Aug 27 15:06:27 2023
**PERF: 4.19 (4.27) 4.20 (4.29) 4.64 (4.29) 4.26 (4.17)
^[[D^[[C
Sun Aug 27 15:06:32 2023
**PERF: 4.05 (4.26) 4.06 (4.28) 4.06 (4.28) 3.75 (4.18)
Sun Aug 27 15:06:37 2023
**PERF: 4.13 (4.27) 4.12 (4.28) 3.54 (4.26) 4.55 (4.17)
Sun Aug 27 15:06:42 2023
**PERF: 4.00 (4.27) 4.35 (4.27) 5.06 (4.27) 4.26 (4.18)
Sun Aug 27 15:06:47 2023
**PERF: 4.76 (4.28) 4.25 (4.28) 3.89 (4.27) 4.52 (4.18)
Sun Aug 27 15:06:52 2023
**PERF: 4.14 (4.27) 3.84 (4.27) 4.64 (4.26) 4.09 (4.18)
Sun Aug 27 15:06:57 2023
**PERF: 4.52 (4.27) 4.81 (4.28) 4.42 (4.28) 4.28 (4.19)
Sun Aug 27 15:07:02 2023
**PERF: 4.39 (4.27) 4.51 (4.29) 4.31 (4.28) 4.66 (4.19)
Sun Aug 27 15:07:07 2023
**PERF: 4.22 (4.28) 3.67 (4.28) 4.42 (4.27) 4.43 (4.20)
Sun Aug 27 15:07:12 2023
**PERF: 4.56 (4.28) 5.21 (4.29) 4.55 (4.29) 4.12 (4.21)
Sun Aug 27 15:07:17 2023
**PERF: 4.45 (4.28) 4.50 (4.29) 4.60 (4.29) 4.64 (4.22)
