Orin AGX runs deepstream example lagging
I am trying the deepstream example in my AGX Orin by following this link.
I have flashed the Orin with SDK manager with deepstream.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#jetson-setup
However, when I run this
$ sudo deepstream-app -c configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
The stream runs smooth for awhile and then, there is lagging. (It is the same for other examples)
All CPU are below 12% and Memory is around 33.4% only)
Here is the message in the terminal. Thx
Using winsys: x11
0:00:02.683902979 96218 0xffff20002350 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.844492633 96218 0xffff20002350 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:02.866315081 96218 0xffff20002350 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:194>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:180>: Pipeline running
**PERF:  FPS 0 (Avg)	FPS 1 (Avg)	FPS 2 (Avg)	FPS 3 (Avg)	FPS 4 (Avg)	FPS 5 (Avg)	FPS 6 (Avg)	FPS 7 (Avg)	FPS 8 (Avg)	FPS 9 (Avg)	FPS 10 (Avg)	FPS 11 (Avg)	FPS 12 (Avg)	FPS 13 (Avg)	FPS 14 (Avg)	FPS 15 (Avg)	FPS 16 (Avg)	FPS 17 (Avg)	FPS 18 (Avg)	FPS 19 (Avg)	FPS 20 (Avg)	FPS 21 (Avg)	FPS 22 (Avg)	FPS 23 (Avg)	FPS 24 (Avg)	FPS 25 (Avg)	FPS 26 (Avg)	FPS 27 (Avg)	FPS 28 (Avg)	FPS 29 (Avg)
**PERF:  16.48 (16.03)	16.15 (15.68)	16.15 (15.68)	16.85 (16.36)	17.90 (17.32)	16.64 (15.39)	16.42 (15.79)	18.38 (17.95)	16.24 (15.79)	18.46 (17.84)	16.15 (15.68)	16.24 (15.79)	16.24 (15.79)	16.15 (15.68)	16.15 (15.68)	15.98 (15.56)	16.24 (15.79)	16.15 (15.68)	16.24 (15.79)	15.98 (15.50)	15.99 (15.39)	16.13 (15.72)	15.99 (15.39)	16.42 (15.79)	16.70 (16.20)	16.75 (16.32)	16.15 (15.68)	15.98 (15.50)	16.15 (15.68)	16.85 (16.36)
**PERF:  15.87 (16.01)	15.87 (15.93)	15.87 (15.93)	16.19 (16.24)	15.82 (16.35)	16.22 (16.31)	15.82 (15.95)	16.19 (16.67)	15.71 (15.64)	15.94 (16.48)	15.91 (15.77)	15.71 (15.64)	15.67 (15.80)	15.91 (15.77)	16.06 (16.08)	16.11 (15.89)	15.71 (15.64)	15.91 (15.77)	15.71 (15.64)	16.11 (15.89)	16.14 (16.01)	15.87 (15.93)	16.02 (16.01)	15.82 (15.95)	15.87 (16.04)	15.87 (16.08)	16.05 (15.77)	15.99 (15.89)	16.06 (16.08)	15.87 (16.08)
**PERF:  15.88 (15.92)	15.85 (15.78)	15.88 (15.87)	15.78 (16.05)	15.68 (16.03)	15.70 (16.00)	16.10 (15.97)	15.55 (16.22)	15.66 (15.71)	15.95 (16.27)	15.81 (15.78)	15.66 (15.71)	16.08 (15.89)	15.83 (15.87)	15.68 (15.87)	15.81 (15.85)	16.03 (15.89)	15.66 (15.78)	15.66 (15.71)	15.66 (15.85)	15.75 (15.92)	15.85 (15.79)	15.68 (15.83)	16.10 (15.97)	15.85 (15.85)	15.70 (15.87)	16.09 (16.05)	15.75 (15.85)	16.08 (16.05)	16.10 (16.05)
**PERF:  15.70 (15.76)	15.87 (15.85)	15.96 (15.85)	15.74 (15.91)	15.64 (15.90)	15.62 (15.88)	15.62 (15.86)	16.04 (16.15)	15.62 (15.68)	15.64 (16.07)	15.99 (15.85)	15.82 (15.74)	15.64 (15.80)	15.96 (15.85)	15.84 (15.85)	15.59 (15.78)	15.76 (15.80)	16.02 (15.85)	15.82 (15.74)	15.62 (15.77)	15.70 (15.76)	15.67 (15.79)	15.90 (15.76)	15.74 (15.86)	15.47 (15.77)	15.62 (15.79)	15.70 (15.85)	15.84 (15.83)	15.56 (15.85)	16.02 (16.03)
**PERF:  15.68 (15.82)	15.74 (15.84)	15.82 (15.88)	15.94 (15.93)	15.93 (15.92)	16.01 (15.86)	15.93 (15.89)	15.81 (16.03)	15.86 (15.71)	16.06 (16.05)	15.62 (15.84)	15.93 (15.80)	15.74 (15.80)	15.62 (15.84)	15.54 (15.79)	15.94 (15.83)	15.82 (15.84)	15.54 (15.79)	15.81 (15.71)	15.86 (15.78)	16.00 (15.86)	16.13 (15.89)	15.88 (15.86)	16.01 (15.94)	15.86 (15.78)	16.33 (15.93)	15.88 (15.93)	15.93 (15.87)	15.62 (15.84)	16.26 (16.07)
WARNING from sink_sub_bin_sink1: A lot of buffers are being dropped.
Debug info: gstbasesink.c(3003): gst_base_sink_is_too_late (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstEglGlesSink:sink_sub_bin_sink1:
There may be a timestamping problem, or this computer is too slow.
**PERF:  15.90 (15.81)	15.58 (15.79)	15.90 (15.87)	15.65 (15.91)	15.78 (15.90)	15.71 (15.89)	15.83 (15.84)	15.83 (16.02)	15.78 (15.72)	15.85 (16.04)	15.78 (15.83)	15.78 (15.80)	16.18 (15.87)	16.38 (15.94)	15.78 (15.79)	15.70 (15.78)	15.78 (15.84)	16.18 (15.87)	15.71 (15.76)	15.85 (15.82)	15.65 (15.85)	15.78 (15.87)	15.70 (15.81)	16.30 (15.99)	15.58 (15.75)	15.78 (15.91)	15.78 (15.91)	15.78 (15.86)	15.70 (15.79)	15.78 (16.02)
**PERF:  15.82 (15.81)	16.35 (15.86)	16.10 (15.92)	16.23 (15.95)	15.95 (15.88)	15.91 (15.81)	16.06 (15.83)	15.31 (15.92)	15.82 (15.74)	15.79 (15.94)	16.15 (15.86)	15.83 (15.80)	15.99 (15.83)	15.91 (15.86)	15.74 (15.76)	16.06 (15.79)	16.32 (15.83)	16.07 (15.86)	15.83 (15.77)	16.23 (15.88)	15.99 (15.81)	15.74 (15.83)	15.94 (15.81)	15.51 (15.93)	15.70 (15.75)	15.63 (15.86)	15.83 (15.89)	16.03 (15.88)	16.22 (15.86)	15.90 (16.02)
**PERF:  15.61 (15.75)	15.54 (15.82)	15.79 (15.88)	15.86 (15.93)	16.07 (15.90)	15.39 (15.81)	15.39 (15.83)	16.40 (15.96)	15.54 (15.72)	15.89 (15.98)	15.61 (15.79)	15.65 (15.77)	15.30 (15.80)	15.58 (15.88)	15.54 (15.74)	15.71 (15.82)	15.39 (15.83)	15.42 (15.82)	15.45 (15.72)	15.65 (15.84)	15.30 (15.78)	15.74 (15.82)	15.55 (15.78)	15.86 (15.91)	15.79 (15.73)	15.86 (15.85)	16.46 (15.96)	15.59 (15.81)	15.61 (15.79)	15.86 (15.99)
**PERF:  15.65 (15.78)	16.06 (15.84)	15.79 (15.89)	16.12 (15.96)	15.72 (15.89)	15.73 (15.81)	15.92 (15.85)	15.99 (15.99)	15.99 (15.73)	16.12 (16.00)	15.79 (15.82)	15.86 (15.77)	16.26 (15.85)	15.73 (15.87)	15.99 (15.75)	15.79 (15.84)	15.86 (15.82)	15.73 (15.82)	15.99 (15.73)	15.92 (15.86)	15.73 (15.78)	15.73 (15.82)	15.79 (15.81)	16.26 (15.94)	15.79 (15.76)	15.73 (15.84)	15.73 (15.94)	15.72 (15.81)	15.65 (15.82)	15.99 (15.96)
**PERF:  16.04 (15.81)	16.10 (15.88)	16.04 (15.90)	16.04 (15.97)	16.30 (15.94)	16.24 (15.85)	15.84 (15.84)	16.04 (15.99)	15.71 (15.73)	16.53 (16.02)	15.90 (15.84)	15.90 (15.80)	16.10 (15.88)	16.44 (15.92)	15.58 (15.75)	16.18 (15.86)	16.30 (15.88)	15.98 (15.82)	15.71 (15.73)	16.04 (15.88)	16.04 (15.81)	16.18 (15.84)	15.84 (15.81)	15.90 (15.95)	15.84 (15.77)	15.98 (15.84)	15.84 (15.92)	15.90 (15.83)	16.44 (15.88)	15.91 (15.97)
**PERF:  16.23 (15.83)	16.15 (15.91)	15.68 (15.87)	16.15 (15.99)	16.08 (15.95)	15.75 (15.84)	16.03 (15.84)	15.55 (15.95)	16.01 (15.78)	15.88 (16.04)	16.08 (15.85)	16.15 (15.84)	15.75 (15.88)	15.95 (15.93)	16.35 (15.81)	15.81 (15.87)	15.75 (15.88)	15.94 (15.83)	15.81 (15.76)	16.03 (15.87)	16.08 (15.83)	16.34 (15.89)	16.08 (15.83)	16.15 (15.97)	15.95 (15.79)	15.81 (15.85)	16.15 (15.95)	16.15 (15.87)	16.15 (15.91)	16.43 (15.99)
**PERF:  15.84 (15.84)	16.12 (15.92)	15.91 (15.87)	15.98 (15.99)	15.98 (15.95)	16.05 (15.84)	15.71 (15.85)	15.98 (15.96)	15.98 (15.80)	15.58 (16.00)	15.65 (15.85)	15.78 (15.83)	16.18 (15.90)	15.78 (15.92)	15.91 (15.81)	15.98 (15.88)	15.91 (15.87)	15.65 (15.83)	15.84 (15.75)	16.10 (15.92)	15.65 (15.82)	15.65 (15.88)	15.65 (15.82)	16.12 (15.98)	15.84 (15.77)	15.78 (15.85)	15.78 (15.94)	15.78 (15.86)	16.12 (15.92)	15.78 (16.01)
**PERF:  15.88 (15.84)	15.75 (15.91)	15.82 (15.88)	15.48 (15.94)	15.75 (15.94)	15.82 (15.85)	15.68 (15.83)	16.08 (15.96)	16.08 (15.81)	15.88 (15.99)	15.88 (15.84)	16.22 (15.85)	15.88 (15.90)	15.61 (15.88)	15.95 (15.83)	15.68 (15.86)	15.88 (15.86)	15.68 (15.81)	15.55 (15.73)	15.68 (15.89)	16.22 (15.84)	15.88 (15.88)	15.68 (15.80)	15.68 (15.94)	15.75 (15.78)	16.42 (15.88)	16.15 (15.93)	16.08 (15.87)	15.75 (15.91)	15.68 (15.98)
**PERF:  15.67 (15.82)	16.15 (15.93)	15.95 (15.89)	15.76 (15.93)	16.00 (15.93)	15.76 (15.85)	15.67 (15.81)	15.56 (15.93)	15.76 (15.81)	15.56 (15.96)	15.76 (15.84)	15.67 (15.83)	15.80 (15.87)	15.63 (15.87)	15.87 (15.83)	15.87 (15.85)	15.83 (15.87)	15.87 (15.81)	15.63 (15.74)	16.07 (15.90)	15.54 (15.82)	15.76 (15.87)	15.67 (15.79)	15.83 (15.95)	15.63 (15.78)	15.43 (15.86)	15.70 (15.93)	15.80 (15.85)	15.80 (15.89)	15.95 (15.98)
**PERF:  15.70 (15.83)	15.94 (15.94)	16.07 (15.89)	15.94 (15.94)	15.70 (15.93)	15.80 (15.83)	15.68 (15.80)	15.74 (15.92)	16.14 (15.84)	15.94 (15.96)	16.07 (15.85)	15.83 (15.84)	15.70 (15.88)	15.74 (15.87)	15.63 (15.82)	15.96 (15.86)	15.74 (15.87)	15.83 (15.82)	16.14 (15.77)	15.83 (15.90)	15.63 (15.82)	15.74 (15.87)	15.88 (15.79)	15.67 (15.92)	16.07 (15.79)	16.14 (15.88)	15.74 (15.92)	15.83 (15.86)	15.89 (15.91)	15.54 (15.95)
**PERF:  15.67 (15.82)	15.88 (15.93)	16.03 (15.89)	15.88 (15.93)	15.88 (15.93)	16.01 (15.86)	15.62 (15.80)	15.88 (15.92)	16.08 (15.85)	15.88 (15.95)	15.74 (15.85)	15.74 (15.84)	15.88 (15.88)	16.08 (15.87)	15.82 (15.81)	15.89 (15.86)	15.88 (15.86)	15.88 (15.82)	15.88 (15.77)	15.82 (15.88)	16.08 (15.83)	15.88 (15.86)	15.76 (15.79)	15.74 (15.92)	15.54 (15.78)	16.08 (15.89)	15.67 (15.90)	16.09 (15.87)	15.88 (15.90)	16.08 (15.95)
**PERF:  15.73 (15.82)	15.73 (15.92)	15.78 (15.89)	15.77 (15.91)	15.73 (15.92)	15.93 (15.86)	15.73 (15.80)	15.73 (15.91)	15.77 (15.84)	15.73 (15.94)	15.93 (15.86)	15.86 (15.84)	15.53 (15.86)	15.73 (15.87)	15.59 (15.81)	15.79 (15.87)	15.93 (15.87)	16.13 (15.85)	15.73 (15.77)	15.99 (15.90)	15.73 (15.83)	15.93 (15.87)	15.59 (15.79)	15.77 (15.90)	15.73 (15.78)	15.73 (15.88)	15.86 (15.89)	15.63 (15.85)	16.18 (15.91)	15.34 (15.92)
**PERF:  16.02 (15.81)	16.31 (15.94)	15.98 (15.90)	15.67 (15.90)	16.11 (15.92)	15.91 (15.86)	16.11 (15.81)	16.02 (15.90)	15.89 (15.83)	16.02 (15.93)	15.93 (15.84)	15.78 (15.83)	16.34 (15.87)	15.71 (15.85)	15.91 (15.81)	15.82 (15.85)	15.91 (15.87)	15.71 (15.83)	15.91 (15.78)	15.82 (15.89)	15.82 (15.81)	15.73 (15.84)	16.43 (15.81)	15.47 (15.88)	15.93 (15.77)	16.11 (15.89)	15.78 (15.89)	15.87 (15.86)	16.09 (15.91)	15.91 (15.91)
** INFO: <bus_callback:217>: Received EOS. Exiting ...
Quitting
App run successful
What is your power mode? 10W/15W/30W?
Jetson AGX Orin — Jetson Linux
Developer Guide 34.1 documentation (nvidia.com)
The upper right corner shows “MAXN”
We have “Jetson Orin NX 8GB”, “Jetson Orin NX 16GB”,“Jetson AGX Orin 32GB” and “Jetson AGX Orin 64GB”, which are you using?
I just checked the System
Processor “ARMv8 Processor rev 1(v8l) x 12”
Graphics NVIDIA Tegra Orin (nvgpu)/Intergrated
Have you used max power and max GPU clock as Performance — DeepStream 6.1.1 Release documentation?
Another improvement is to use VPI max clock as VPI - Vision Programming Interface: Performance Benchmark (nvidia.com)
We have performance data in Performance — DeepStream 6.1.1 Release documentation
Jetson AGX Orin Development Kit
945-13730-0000000
I’ve flashed the Orin with SDK manager before, do I need to set anything like clock speed?
Thx
Yes. Please read the document.
So, do you mean the Orin hardware is defective?
I mean you run the 30 stream case which is a performance case. You need to set up as performance case.
If the right upper corner shows MAXN, is it max performance?
I can duplicate your problem. We are debugging this issue. We’ll let you know as soon as we have a conclusion. Thanks
ok, good to know thx
I have also tried these, same problem.
sudo nvpmodel -m 0
sudo jetson_clocks
But we may not support very well about your test example configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt. Cause it have 30 1080p streams. You can refer the link below to find the limit of your board.
https://developer.nvidia.com/embedded/jetson-modules
We just debug for other examples you said. So could you attach all the other examples you tested?
Our plan is to use Orin AGX for object detection. As many cameras as possible in real time.
I understand 30 cameras may push the limit. I just bought this Orin and want to do all these testing right now.
This example is not important, I just wonder if my Orin is defective.
Don’t worry. Thx
Hi @AK51 , I test it in my Orin board. It works well when play in the limit of the doc. So could you you run again through the following points? Thanks
1.Observe board restrictions, please refer the link below:
[https://developer.nvidia.com/embedded/jetson-modules](https://developer.nvidia.com/embedded/jetson-modules)
2.When you change the number of sources,  you should change the `[streammux] batch-size`
para. Set the para to the number of your sources.
Dear Yuweiw,
May I know what shall I do for running the example? I have a AGX Orin 64Gb.
I am not familiar with
Where is the setting?
Here is what I did by following the document, Quickstart Guide — DeepStream 6.1.1 Release documentation
Thx
nvidia@ubuntu:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app$ sudo deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
====>Where is the setting?
You can modify the source30_1080p_dec_infer-resnet_tiled_display_int8.txt file. For example, change the num-sources = 2.
I think you should know some basic knowledge about gstreamer and some nvidia plugins for deepstream. Thanks
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_sample_configs_streams.html
Dear Yuweiw,
I finally know what you mean, the sample is not for AGX Orin, I have to modify the txt so as to run the example smoothly.
After testing, Orin AGX can only support up to 16 videos.
Below is the txt file for reference.
But there is no way to run 30 videos in Orin, right?
Thx
# Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=5
columns=6
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../streams/sample_1080p_h264.mp4
num-sources=8
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device   - Memory type Device
# (1): memtype_pinned   - Memory type Host Pinned
# (2): memtype_unified  - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=8
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 7=nv3dsink (Jetson only)
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=16
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=16
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tests]
file-loop=0
