• Hardware Platform (Jetson XAVIER / GPU)
• DeepStream Version 5.0.0
• JetPack Version (valid for Jetson only) 4.4
• TensorRT Version 7.1
• NVIDIA GPU Driver Version (valid for GPU only) 10.2
• When i execute deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt set type=4 in sink2, the fps is too low?
• I also execute sudo nvpmodel -m 0 and sudo jetson_clocks before run deepstream-app
The log information as below,
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Opening in BLOCKING MODE
Using winsys: x11
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine open error
0:00:01.211111179 24587 0x7f38002270 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:01.211345052 24587 0x7f38002270 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:01.211406281 24587 0x7f38002270 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
INFO: [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: [TRT]:
INFO: [TRT]: --------------- Layers running on DLA:
INFO: [TRT]:
INFO: [TRT]: --------------- Layers running on GPU:
INFO: [TRT]: conv1 + activation_1/Relu, block_1a_conv_1 + activation_2/Relu, block_1a_conv_2, block_1a_conv_shortcut + add_1 + activation_3/Relu, block_2a_conv_1 + activation_4/Relu, block_2a_conv_2, block_2a_conv_shortcut + add_2 + activation_5/Relu, block_3a_conv_1 + activation_6/Relu, block_3a_conv_2, block_3a_conv_shortcut + add_3 + activation_7/Relu, block_4a_conv_1 + activation_8/Relu, block_4a_conv_2, block_4a_conv_shortcut + add_4 + activation_9/Relu, conv2d_cov, conv2d_cov/Sigmoid, conv2d_bbox,
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine opened error
0:00:30.133370731 24587 0x7f38002270 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:30.155050011 24587 0x7f38002270 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg) FPS 10 (Avg) FPS 11 (Avg) FPS 12 (Avg) FPS 13 (Avg) FPS 14 (Avg) FPS 15 (Avg) FPS 16 (Avg) FPS 17 (Avg) FPS 18 (Avg) FPS 19 (Avg) FPS 20 (Avg) FPS 21 (Avg) FPS 22 (Avg) FPS 23 (Avg) FPS 24 (Avg)FPS 25 (Avg) FPS 26 (Avg) FPS 27 (Avg) FPS 28 (Avg) FPS 29 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
** INFO: <bus_callback:167>: Pipeline running
**PERF: 4.55 (4.21) 4.75 (4.42) 4.55 (4.21) 4.55 (4.21) 4.55 (4.21) 4.75 (4.42) 4.55 (4.21) 4.55 (4.21) 4.59 (4.26) 4.63 (4.31) 4.55 (4.21) 4.55 (4.21) 4.67 (4.35) 4.75 (4.42) 4.59 (4.26) 4.75 (4.42) 4.55 (4.21) 4.55 (4.21) 4.00 (3.69) 4.55 (4.21) 4.55 (4.21) 4.55 (4.21) 4.55 (4.21) 4.19 (3.87) 4.55 (4.21) 4.55 (4.21) 4.55 (4.21) 4.19 (3.87) 4.63 (4.31) 4.55 (4.21)
**PERF: 3.03 (3.67) 3.03 (3.78) 3.03 (3.67) 3.03 (3.67) 3.03 (3.67) 3.03 (3.78) 3.03 (3.67) 3.03 (3.67) 3.03 (3.70) 3.03 (3.74) 3.03 (3.67) 3.03 (3.67) 3.03 (3.75) 3.03 (3.78) 3.03 (3.70) 3.03 (3.78) 3.03 (3.67) 3.03 (3.67) 3.03 (3.42) 3.03 (3.67) 3.03 (3.67) 3.03 (3.67) 3.03 (3.67) 3.03 (3.50) 3.03 (3.67) 3.03 (3.67) 3.03 (3.67) 3.03 (3.50) 3.03 (3.74) 3.03 (3.67)
WARNING from sink_sub_bin_sink1: A lot of buffers are being dropped.
Debug info: gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstEglGlesSink:sink_sub_bin_sink1:
There may be a timestamping problem, or this computer is too slow.
**PERF: 5.12 (3.99) 5.12 (4.06) 5.12 (3.99) 5.12 (3.99) 5.12 (3.99) 5.12 (4.06) 5.12 (3.99) 5.12 (3.99) 5.12 (4.01) 5.12 (4.03) 5.12 (3.99) 4.90 (3.92) 5.12 (4.04) 5.12 (4.06) 5.12 (4.01) 5.12 (4.06) 5.12 (3.99) 5.12 (3.99) 5.12 (3.84) 5.12 (3.99) 5.12 (3.99) 5.12 (3.99) 5.12 (3.99) 5.12 (3.89) 5.12 (3.99) 5.12 (3.99) 5.12 (3.99) 5.12 (3.89) 5.12 (4.03) 5.12 (3.99)
**PERF: 4.48 (4.10) 4.48 (4.15) 4.48 (4.10) 4.48 (4.10) 4.48 (4.10) 4.28 (4.10) 4.48 (4.10) 4.28 (4.05) 4.48 (4.11) 4.48 (4.12) 4.48 (4.10) 4.48 (4.05) 4.48 (4.13) 4.48 (4.15) 4.48 (4.11) 4.48 (4.15) 4.48 (4.10) 4.48 (4.10) 4.48 (3.99) 4.48 (4.10) 4.48 (4.10) 4.48 (4.10) 4.28 (4.05) 4.48 (4.02) 4.48 (4.10) 4.48 (4.10) 4.48 (4.10) 4.48 (4.02) 4.48 (4.12) 4.48 (4.10)
**PERF: 3.40 (4.04) 3.40 (4.08) 3.58 (4.08) 3.58 (4.08) 3.58 (4.08) 3.58 (4.08) 3.58 (4.08) 3.40 (4.00) 3.58 (4.09) 3.58 (4.10) 3.58 (4.08) 3.58 (4.04) 3.58 (4.11) 3.58 (4.12) 3.58 (4.09) 3.58 (4.12) 3.58 (4.08) 3.58 (4.08) 3.58 (3.99) 3.58 (4.08) 3.58 (4.08) 3.58 (4.08) 3.58 (4.04) 3.58 (4.02) 3.58 (4.08) 3.58 (4.08) 3.58 (4.08) 3.58 (4.02) 3.58 (4.10) 3.58 (4.08)
**PERF: 5.61 (4.20) 5.61 (4.23) 5.61 (4.24) 5.61 (4.24) 5.61 (4.24) 5.61 (4.23) 5.61 (4.24) 5.61 (4.17) 5.61 (4.24) 5.61 (4.25) 5.61 (4.24) 5.61 (4.20) 5.61 (4.26) 5.61 (4.27) 5.61 (4.24) 5.61 (4.27) 5.61 (4.24) 5.61 (4.24) 5.61 (4.16) 5.61 (4.24) 5.61 (4.24) 5.61 (4.24) 5.61 (4.20) 5.61 (4.19) 5.61 (4.24) 5.61 (4.24) 5.61 (4.24) 5.61 (4.19) 5.61 (4.25) 5.61 (4.24)
**PERF: 4.38 (4.29) 4.38 (4.31) 4.38 (4.32) 4.38 (4.32) 4.38 (4.32) 4.38 (4.31) 4.38 (4.32) 4.38 (4.26) 4.38 (4.32) 4.38 (4.33) 4.38 (4.32) 4.38 (4.29) 4.38 (4.33) 4.38 (4.34) 4.38 (4.32) 4.38 (4.34) 4.38 (4.32) 4.38 (4.32) 4.38 (4.26) 4.38 (4.32) 4.38 (4.32) 4.38 (4.32) 4.38 (4.29) 4.38 (4.28) 4.38 (4.32) 4.38 (4.32) 4.38 (4.32) 4.38 (4.28) 4.38 (4.33) 4.38 (4.32)
**PERF: 4.58 (4.30) 4.58 (4.33) 4.58 (4.33) 4.58 (4.33) 4.58 (4.33) 4.37 (4.30) 4.58 (4.33) 4.58 (4.28) 4.58 (4.33) 4.58 (4.34) 4.58 (4.33) 4.58 (4.30) 4.37 (4.32) 4.58 (4.35) 4.58 (4.33) 4.58 (4.35) 4.58 (4.33) 4.37 (4.30) 4.58 (4.27) 4.58 (4.33) 4.58 (4.33) 4.58 (4.33) 4.58 (4.30) 4.58 (4.29) 4.58 (4.33) 4.58 (4.33) 4.58 (4.33) 4.37 (4.27) 4.58 (4.34) 4.58 (4.33)
Thanks.!
