Is this critical or do I need to worry about it?
and if not
How do I disable this warning?
this just started with the upgrad to 11.1 and using the 32bit version
and seems to happen on a divide of a Real*4 number
for example the values are
21.309 / 0.002
will cause this message
Warning: ieee_inexact is signaling
Blame the F2003 standard. The standard requires that these IEEE warning be emitted when the program exits via a STOP statement.
I guess that you depend upon what you are doing. If your program needs exact answers then yes, it would be critical. If your program allows for some loss of accuracy, then you can ignore them.
