Hereby I attached the bug report after running nvidia-bug-report.sh nvidia-bug-report.log.gz (311.6 KB)
I have a gamer laptop HP-victus 16, and I am dual booting with Windows 11. The problem I have is that I am having lag and short freezes when opening apps and switching between them. Curiously, everything works fine as long as I use an external monitor.
I have exactly the same problem: This problem is happening on Lenovo Legion 5 Pro 16. Dual boot system with Windows 10 in separate SSD, Could you suggest something to fix this? Thanks.
@generix Hi, Iām having the same issue , I had the drivers installed I guess also when I tried nvidia-smi I get this error.
konki@konki:~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I would appreciate a little help. Thanks. data (2.2 MB)
Here is the bug report.
Could affect the monitor in someway to the nvidia-drivers ?
I am having the same problem.
I can manage to install the Nvidia-driver-510 successfully, and even I can install Cuda package and run GPU commutations with my Cuda⦠But after one day, I get a a broken dependency error from Nvidia deriver and even the command nvidia-smi does not work anymore and does not return any correct output.
It seems that somehow the different Ubuntu repos for Nvidia-driver-510 is messed up.
I got the same problem just after my laptop auto updated its bios version.
With the same output and nvidia-smi was disabled.
Then I found BIOSās secure boot is enabled,so just disable it and all problems are solved.
@KHTeh the driver modules dināt compile, please try reinstalling the kernel headers
sudo apt install --reinstall linux-headers-$(uname -r)
then post the output of
dkms status
I have got the exact same problem with the same report as the users in this thread.
This is the output of ādkms statusā: nvidia, 510.47.03, 5.13.0-40-generic, x86_64: installed
@mariemkhlifi16 since the module is installed, please check secure boot status, check if you need to run prime-select, check for blacklist files.
or create a nvidia-bug-report.log.
Ok, one question: do you think connecting to a machine via teamviewer has an influence on all of this? The drivers are installed, there is no mention of nvidia in blacklist.conf but it doesnāt seem that the machine can communicate with them.
I have the next error:
NVIDIA-SMI has failed because it couldnāt communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
When a enter the ubuntu-drivers devices i got the message below,
WARNING:root:_pkg_get_support nvidia-driver-510-server: package has invalid Support PBheader, cannot determine support level
== /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0 ==
modalias : pci:v000010DEd000025E0sv000017AAsd00003AACbc03sc00i00
vendor : NVIDIA Corporation
driver : nvidia-driver-460 - third-party non-free
driver : nvidia-driver-510-server - distro non-free
driver : nvidia-driver-495 - third-party non-free
driver : nvidia-driver-470-server - distro non-free
driver : nvidia-driver-470 - third-party non-free
driver : nvidia-driver-510 - third-party non-free recommended
driver : xserver-xorg-video-nouveau - distro free builtin
I install the drivers by different methods and other drivers but always have the same problems
I have secure boot disabled and the bouveau driver in a blacklisted, but nothing.
also I get the following error with the command nvidia-settings
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this
driver at /usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot
be prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions.
finally when a run modprobe nvidia i get:
modprobe: FATAL: Module nvidia not found in directory /lib/modules/5.17.4-051704-generic
Here is the bug report I hope any of you can help me, I really appreciate. nvidia-bug-report.log.gz (137.4 KB)
