Hello just a heads up Nvidia Sli does not work on the Lenovo Y510p our Intel chip is disabled by Lenovo in the bios so we only have our 2 750m’s in sli but no matter what cannot get it to work with Sli=on sli=auto sli=AFR etc. comp freezes at start and this has been posted around the ubuntu forums with no fix yet.
[code]
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 16503883
Date: Thu Oct 24 20:02:40 EDT 2013
uname: Linux jerry-Lenovo-IdeaPad-Y510P 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:20:46 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 20 2013-10-13 16:41:50.000000000 -0400 /etc/issue
Ubuntu 13.10 \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 11 2012-10-27 23:43:19.000000000 -0400 /etc/debian_version
wheezy/sid
*** /var/log/nvidia-installer.log does not exist
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 7675 2013-10-24 19:58:31.874903119 -0400 /var/log/Xorg.0.log
[ 8.673]
X.Org X Server 1.14.3
Release Date: 2013-09-12
[ 8.673] X Protocol Version 11, Revision 0
[ 8.673] Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
[ 8.673] Current Operating System: Linux jerry-Lenovo-IdeaPad-Y510P 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:20:46 UTC 2013 x86_64
[ 8.673] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-12-generic.efi.signed root=UUID=5f37d7ef-187e-48e2-96d5-f4095b8b9efd ro nomodeset text
[ 8.673] Build Date: 15 October 2013 09:23:37AM
[ 8.673] xorg-server 2:1.14.3-3ubuntu2 (For technical support please see Enterprise open source support | Ubuntu)
[ 8.673] Current version of pixman: 0.30.2
[ 8.673] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 8.673] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 8.673] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Oct 24 19:58:31 2013
[ 8.673] (==) Using config file: “/etc/X11/xorg.conf”
[ 8.673] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 8.673] (==) ServerLayout “Layout0”
[ 8.673] () |–>Screen “Screen0” (0)
[ 8.673] () | |–>Monitor “Monitor0”
[ 8.674] () | |–>Device “Device0”
[ 8.674] () |–>Input Device “Keyboard0”
[ 8.674] () |–>Input Device “Mouse0”
[ 8.674] (==) Automatically adding devices
[ 8.674] (==) Automatically enabling devices
[ 8.674] (==) Automatically adding GPU devices
[ 8.676] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 8.676] Entry deleted from font path.
[ 8.676] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 8.676] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 8.676] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 8.676] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 8.676] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 8.676] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 8.676] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 8.676] (WW) Disabling Keyboard0
[ 8.676] (WW) Disabling Mouse0
[ 8.676] (II) Loader magic: 0x7f60fd8e3d20
[ 8.676] (II) Module ABI versions:
[ 8.676] X.Org ANSI C Emulation: 0.4
[ 8.676] X.Org Video Driver: 14.1
[ 8.676] X.Org XInput driver : 19.1
[ 8.676] X.Org Server Extension : 7.0
[ 8.676] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 8.676] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 8.677] (–) PCI:*(0:1:0:0) 10de:0fe4:17aa:3800 rev 161, Mem @ 0xd3000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x???/524288
[ 8.677] (–) PCI: (0:7:0:0) 10de:0fe4:17aa:3800 rev 161, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00004000/128
[ 8.677] (II) Open ACPI successful (/var/run/acpid.socket)
[ 8.677] Initializing built-in extension Generic Event Extension
[ 8.677] Initializing built-in extension SHAPE
[ 8.677] Initializing built-in extension MIT-SHM
[ 8.677] Initializing built-in extension XInputExtension
[ 8.677] Initializing built-in extension XTEST
[ 8.677] Initializing built-in extension BIG-REQUESTS
[ 8.677] Initializing built-in extension SYNC
[ 8.677] Initializing built-in extension XKEYBOARD
[ 8.677] Initializing built-in extension XC-MISC
[ 8.677] Initializing built-in extension SECURITY
[ 8.677] Initializing built-in extension XINERAMA
[ 8.677] Initializing built-in extension XFIXES
[ 8.677] Initializing built-in extension RENDER
[ 8.677] Initializing built-in extension RANDR
[ 8.677] Initializing built-in extension COMPOSITE
[ 8.677] Initializing built-in extension DAMAGE
[ 8.678] Initializing built-in extension MIT-SCREEN-SAVER
[ 8.678] Initializing built-in extension DOUBLE-BUFFER
[ 8.678] Initializing built-in extension RECORD
[ 8.678] Initializing built-in extension DPMS
[ 8.678] Initializing built-in extension X-Resource
[ 8.678] Initializing built-in extension XVideo
[ 8.678] Initializing built-in extension XVideo-MotionCompensation
[ 8.678] Initializing built-in extension SELinux
[ 8.678] Initializing built-in extension XFree86-VidModeExtension
[ 8.678] Initializing built-in extension XFree86-DGA
[ 8.678] Initializing built-in extension XFree86-DRI
[ 8.678] Initializing built-in extension DRI2
[ 8.678] (II) “glx” will be loaded by default.
[ 8.678] (WW) “xmir” is not to be loaded by default. Skipping.
[ 8.678] (II) LoadModule: “dri2”
[ 8.678] (II) Module “dri2” already built-in
[ 8.678] (II) LoadModule: “glamoregl”
[ 8.678] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 8.694] (EE) Failed to load /usr/lib/xorg/modules/libglamoregl.so: /usr/lib/xorg/modules/libglamoregl.so: undefined symbol: _glapi_tls_Context
[ 8.694] (II) UnloadModule: “glamoregl”
[ 8.694] (II) Unloading glamoregl
[ 8.694] (EE) Failed to load module “glamoregl” (loader failed, 7)
[ 8.694] (II) LoadModule: “glx”
[ 8.694] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 8.717] (II) Module glx: vendor=“NVIDIA Corporation”
[ 8.717] compiled for 4.0.2, module version = 1.0.0
[ 8.717] Module class: X.Org Server Extension
[ 8.717] (II) NVIDIA GLX Module 331.17 Thu Oct 17 09:30:48 PDT 2013
[ 8.717] Loading extension GLX
[ 8.717] (II) LoadModule: “nvidia”
[ 8.717] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 8.717] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 8.717] Module class: X.Org Video Driver
[ 8.717] (II) NVIDIA dlloader X Driver 331.17 Thu Oct 17 09:11:05 PDT 2013
[ 8.717] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 8.717] (–) using VT number 7
[ 8.723] (II) Loading sub module “fb”
[ 8.723] (II) LoadModule: “fb”
[ 8.723] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 8.723] (II) Module fb: vendor=“X.Org Foundation”
[ 8.723] compiled for 1.14.3, module version = 1.0.0
[ 8.723] ABI class: X.Org ANSI C Emulation, version 0.4
[ 8.723] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 8.723] (II) Loading sub module “wfb”
[ 8.723] (II) LoadModule: “wfb”
[ 8.724] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 8.724] (II) Module wfb: vendor=“X.Org Foundation”
[ 8.724] compiled for 1.14.3, module version = 1.0.0
[ 8.724] ABI class: X.Org ANSI C Emulation, version 0.4
[ 8.724] (II) Loading sub module “ramdac”
[ 8.724] (II) LoadModule: “ramdac”
[ 8.724] (II) Module “ramdac” already built-in
[ 8.724] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 8.724] (==) NVIDIA(0): RGB weight 888
[ 8.724] (==) NVIDIA(0): Default visual is TrueColor
[ 8.724] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 8.724] () NVIDIA(0): Option “SLI” “on”
[ 8.724] () NVIDIA(0): NVIDIA SLI auto-select rendering option.
[ 8.724] () NVIDIA(0): Enabling 2D acceleration
*** /etc/X11/xorg.conf
*** ls: -rw-r–r-- 1 root root 1362 2013-10-24 19:56:16.063910841 -0400 /etc/X11/xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 331.17 (buildmeister@swio-display-x64-rhel04-18) Thu Oct 17 10:15:46 PDT 2013
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “SLI” “on”
SubSection “Display”
Depth 24
EndSubSection
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2013-10-15 05:26:06.000000000 -0400 /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Section “InputClass”
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
MatchIsKeyboard “on”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2013-07-04 08:35:13.000000000 -0400 /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
Identifier “Avago Technologies mouse quirks (LP: #746639)”
MatchIsPointer “on”
Driver “evdev”
MatchUSBID “192f:0416”
Option “Emulate3Buttons” “True”
Option “Emulate3Timeout” “50”
EndSection
X/Y axis not working due to device reporting absolute axes
https://bugs.launchpad.net/ubuntu/+source/xserver-xorg-input-evdev/+bug/325581
32882 – kensington pocket mouse model #72237 USB 0d62:1000 not working
Identifier “Benq m310”
MatchProduct “HID 0d62:1000”
Driver “evdev”
Option “IgnoreAbsoluteAxes” “true”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
*** ls: -rw-r–r-- 1 root root 364 2013-07-04 08:35:13.000000000 -0400 /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
trackpoint users want wheel emulation
Identifier “trackpoint catchall”
MatchIsPointer “true”
MatchProduct “TrackPoint|DualPoint Stick”
Option “Emulate3Buttons” “true”
Option “EmulateWheel” “true”
Option “EmulateWheelButton” “2”
Option “XAxisMapping” “6 7”
Option “YAxisMapping” “4 5”
EndSection
*** /usr/share/X11/xorg.conf.d/50-synaptics.conf
*** ls: -rw-r–r-- 1 root root 1757 2013-07-25 09:38:37.000000000 -0400 /usr/share/X11/xorg.conf.d/50-synaptics.conf
Example xorg.conf.d snippet that assigns the touchpad driver
to all touchpads. See xorg.conf.d(5) for more information on
InputClass.
DO NOT EDIT THIS FILE, your distribution will likely overwrite
it when updating. Copy (and rename) this file into
/etc/X11/xorg.conf.d first.
Additional options may be added in the form of
Option “OptionName” “value”
Identifier “touchpad catchall”
Driver “synaptics”
This option is recommend on all Linux systems using evdev, but cannot be
enabled by default. See the following link for details:
Who-T: How to ignore configuration errors
MatchDevicePath "/dev/input/event*"
EndSection
Identifier “touchpad ignore duplicates”
MatchOS “Linux”
MatchDevicePath “/dev/input/mouse*”
Option “Ignore” “on”
EndSection
This option enables the bottom right corner to be a right button on
non-synaptics clickpads.
This option is only interpreted by clickpads.
Identifier “Default clickpad buttons”
MatchDriver “synaptics”
Option “SoftButtonAreas” “50% 0 82% 0 0 0 0 0”
To disable the bottom edge area so the buttons only work as buttons,
not for movement, set the AreaBottomEdge
Option “AreaBottomEdge” “82%”
EndSection
This option disables software buttons on Apple touchpads.
Identifier “Disable clickpad buttons on Apple touchpads”
MatchProduct “Apple|bcm5974”
Option “SoftButtonAreas” “0 0 0 0 0 0 0 0”
EndSection
*** /usr/share/X11/xorg.conf.d/50-vmmouse.conf
*** ls: -rw-r–r-- 1 root root 115 2013-07-04 08:37:23.000000000 -0400 /usr/share/X11/xorg.conf.d/50-vmmouse.conf
Identifier “vmmouse”
MatchIsPointer “on”
MatchTag “vmmouse”
Driver “vmmouse”
EndSection
*** /usr/share/X11/xorg.conf.d/50-wacom.conf
*** ls: -rw-r–r-- 1 root root 842 2013-08-29 09:04:53.000000000 -0400 /usr/share/X11/xorg.conf.d/50-wacom.conf
Identifier “Wacom class”
MatchProduct “Wacom|WACOM|Hanwang|PTK-540WL|ISD-V4”
Driver “wacom”
EndSection
Identifier “Wacom serial class”
MatchProduct “Serial Wacom Tablet”
Driver “wacom”
EndSection
Identifier “Wacom serial class identifiers”
MatchProduct “WACf|FUJ02e5|FUJ02e7|FUJ02e9”
Driver “wacom”
EndSection
Waltop tablets
Identifier “Waltop class”
MatchProduct “WALTOP”
MatchIsTablet “on”
Driver “wacom”
EndSection
N-Trig Duosense Electromagnetic Digitizer
Identifier “Wacom N-Trig class”
MatchProduct “HID 1b96:0001|N-Trig Pen”
Driver “wacom”
Option “Button2” “3”
EndSection
*** /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2013-07-25 09:38:16.000000000 -0400 /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
Identifier “Dell Inspiron embedded buttons quirks”
MatchTag “inspiron_1011|inspiron_1012”
Driver “synaptics”
Option “JumpyCursorThreshold” “90”
EndSection
Identifier “Dell Inspiron quirks”
MatchTag “inspiron_1120”
Driver “synaptics”
Option “JumpyCursorThreshold” “250”
EndSection
Identifier “HP Mininote quirks”
MatchTag “mininote_1000”
Driver “synaptics”
Option “JumpyCursorThreshold” “20”
EndSection
*** /usr/share/X11/xorg.conf.d/glamor.conf
*** ls: -rw-r–r-- 1 root root 61 2013-10-01 10:44:02.000000000 -0400 /usr/share/X11/xorg.conf.d/glamor.conf
Section “Module”
Load “dri2”
Load “glamoregl”
EndSection
*** /home/jerry/.nvidia-settings-rc
*** ls: -rw-r–r-- 1 jerry jerry 1949 2013-10-23 22:24:32.295665193 -0400 /home/jerry/.nvidia-settings-rc
Configuration file for nvidia-settings - the NVIDIA X Server Settings utility
Generated on Wed Oct 23 22:24:32 2013
ConfigProperties:
RcFileLocale = C
ToolTips = Yes
DisplayStatusBar = Yes
SliderTextEntries = Yes
IncludeDisplayNameInConfigFile = No
ShowQuitDialog = Yes
UpdateRulesOnProfileNameChange = Yes
Timer = PowerMizer_Monitor_(GPU_1),Yes,1000
Timer = Thermal_Monitor_(GPU_1),Yes,1000
Timer = Memory_Used_(GPU_1),Yes,3000
Timer = PowerMizer_Monitor_(GPU_0),Yes,1000
Timer = Thermal_Monitor_(GPU_0),Yes,1000
Timer = Memory_Used_(GPU_0),Yes,3000
Attributes:
0/SyncToVBlank=1
0/LogAniso=0
0/FSAA=0
0/TextureSharpen=0
0/TextureClamping=1
0/FXAA=0
0/AllowFlipping=1
0/FSAAAppControlled=1
0/LogAnisoAppControlled=1
0/OpenGLImageSettings=2
0/FSAAAppEnhanced=0
0/XVideoSyncToDisplayID=VGA-0
[DPY:VGA-0]/Dithering=0
[DPY:VGA-0]/DitheringMode=0
[DPY:VGA-0]/DitheringDepth=0
[DPY:VGA-0]/SynchronousPaletteUpdates=0
[DPY:LVDS-0]/Dithering=0
[DPY:LVDS-0]/DitheringMode=0
[DPY:LVDS-0]/DitheringDepth=0
[DPY:LVDS-0]/SynchronousPaletteUpdates=0
[DPY:HDMI-0]/Dithering=0
[DPY:HDMI-0]/DitheringMode=0
[DPY:HDMI-0]/DitheringDepth=0
[DPY:HDMI-0]/SynchronousPaletteUpdates=0
[DPY:DP-0]/RedBrightness=0.000000
[DPY:DP-0]/GreenBrightness=0.000000
[DPY:DP-0]/BlueBrightness=0.000000
[DPY:DP-0]/RedContrast=0.000000
[DPY:DP-0]/GreenContrast=0.000000
[DPY:DP-0]/BlueContrast=0.000000
[DPY:DP-0]/RedGamma=1.000000
[DPY:DP-0]/GreenGamma=1.000000
[DPY:DP-0]/BlueGamma=1.000000
[DPY:DP-0]/Dithering=0
[DPY:DP-0]/DitheringMode=0
[DPY:DP-0]/DitheringDepth=0
[DPY:DP-0]/DigitalVibrance=596
[DPY:DP-0]/ColorSpace=0
[DPY:DP-0]/ColorRange=0
[DPY:DP-0]/SynchronousPaletteUpdates=0
*** /usr/share/nvidia/nvidia-application-profiles-331.17-rc
*** ls: lrwxrwxrwx 1 root root 53 2013-10-23 13:07:47.638277812 -0400 /usr/share/nvidia/nvidia-application-profiles-331.17-rc → /etc/alternatives/x86_64-linux-gnu_nvidia_app_profile
Application profiles for the NVIDIA Linux graphics driver, version 331.17
Last modified: Thu Oct 17 09:33:59 PDT 2013
These profiles were provided by NVIDIA and should not be modified. If you
wish to change the defaults provided here, you can override them by creating
custom rules in /etc/nvidia/nvidia-application-profiles-rc (which will apply
system-wide) or, for a given user, $HOME/.nv/nvidia-application-profiles-rc
(which will apply to that particular user). See the "APPLICATION PROFILE
SEARCH PATH" section of the NVIDIA Linux Graphics Driver README for more
information.
“profiles” : [
“name” : “NonConformantBlitFramebufferScissor”,
“settings” : [ “GLConformantBlitFramebufferScissor”, false ]
{ “name” : “CL1C”,
“settings” : [ “0x528ab3”, 1 ] }
“rules” : [
# Work around GNOME bug 690451 (see
# Bug 690451 – cogl calls glBlitFramebuffer with a 0x0 scissor enabled)
“pattern” : {
“feature” : “dso”,
“matches” : “libcogl.so”
“profile” : “NonConformantBlitFramebufferScissor”
{ “pattern” : “Maya2014”, “profile” : “CL1C” },
{ “pattern” : “xsi”, “profile” : “CL1C” },
{ “pattern” : “HoudiniFX”, “profile” : “CL1C” },
{ “pattern” : “katana”, “profile” : “CL1C” },
{ “pattern” : “Autodesk Mudbox 2014 64-bit”, “profile” : “CL1C” },
{ “pattern” : “octane”, “profile” : “CL1C” },
{ “pattern” : “Fusion64_6.4”, “profile” : “CL1C” },
{ “pattern” : “Nuke7.0”, “profile” : “CL1C” },
{ “pattern” : “vray.exe”, “profile” : “CL1C” },
{ “pattern” : “vray.bin”, “profile” : “CL1C” }
Skipping ldd output (glxinfo not found)
/usr/bin/lspci -d “10de:*” -v -xxx
01:00.0 VGA compatible controller: NVIDIA Corporation GK107M [GeForce GT 750M] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 3800
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at d3000000 (32-bit, non-prefetchable)
Memory at a0000000 (64-bit, prefetchable)
Memory at b0000000 (64-bit, prefetchable)
I/O ports at 5000
[virtual] Expansion ROM at b2000000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel driver in use: nvidia
00: de 10 e4 0f 07 00 10 00 a1 00 00 03 00 00 80 00
10: 00 00 00 d3 0c 00 00 a0 00 00 00 00 0c 00 00 b0
20: 00 00 00 00 01 50 00 00 00 00 00 00 aa 17 00 38
30: 00 00 00 00 60 00 00 00 00 00 00 00 00 01 00 00
40: aa 17 00 38 00 00 00 00 00 00 00 00 00 00 00 00
50: 00 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 80 00 0c f0 ef fe
70: 00 00 00 00 c2 41 00 00 10 b4 02 00 e1 8d 2c 01
80: 30 29 00 00 03 3d 45 00 40 01 81 10 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
a0: 00 00 00 00 0e 00 00 00 03 00 3f 00 00 00 00 00
b0: 00 00 00 00 09 00 14 01 01 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01:00.1 Audio device: NVIDIA Corporation GK107 HDMI Audio Controller (rev a1)
Subsystem: Lenovo Device 3978
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at d4000000 (32-bit, non-prefetchable)
Kernel driver in use: snd_hda_intel
00: de 10 1b 0e 06 00 10 00 a1 00 03 04 10 00 80 00
10: 00 00 00 d4 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 aa 17 78 39
30: 00 00 00 00 60 00 00 00 00 00 00 00 00 02 00 00
40: aa 17 78 39 00 00 00 00 00 00 00 00 00 00 00 00
50: 00 00 00 00 00 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 02 00 e1 8d 2c 01
a0: 00 00 00 00 0e 00 00 00 00 00 3f 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
07:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 750M] (rev a1)
Memory at d2000000 (32-bit, non-prefetchable)
Memory at c0000000 (64-bit, prefetchable)
Memory at d0000000 (64-bit, prefetchable)
I/O ports at 4000
00: de 10 e4 0f 07 00 10 00 a1 00 02 03 00 00 00 00
10: 00 00 00 d2 0c 00 00 c0 00 00 00 00 0c 00 00 d0
20: 00 00 00 00 01 40 00 00 00 00 00 00 aa 17 00 38
50: 01 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
70: 00 00 00 00 d2 41 00 00 10 b4 02 00 e1 8d 2c 01
80: 10 29 00 00 03 3d 45 01 40 01 81 10 00 00 00 00
b0: 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
/usr/bin/lspci -d “10b5:*” -v -xxx
/usr/bin/lspci -t
-[0000:00]-±00.0
±01.0-[01-06]–±00.0
| -00.1
±01.1-[07]----00.0
±14.0
±16.0
±1a.0
±1b.0
±1c.0-[08]–
±1c.3-[09]----00.0
±1c.4-[0a]----00.0
±1d.0
±1f.0
±1f.2
-1f.3
/usr/bin/lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller [8086:0c04] (rev 06)
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller [8086:0c01] (rev 06)
00:01.1 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x8 Controller [8086:0c05] (rev 06)
00:14.0 USB controller [0c03]: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI [8086:8c31] (rev 04)
00:16.0 Communication controller [0780]: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 [8086:8c3a] (rev 04)
00:1a.0 USB controller [0c03]: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 [8086:8c2d] (rev 04)
00:1b.0 Audio device [0403]: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller [8086:8c20] (rev 04)
00:1c.0 PCI bridge [0604]: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 [8086:8c10] (rev d4)
00:1c.3 PCI bridge [0604]: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 [8086:8c16] (rev d4)
00:1c.4 PCI bridge [0604]: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #5 [8086:8c18] (rev d4)
00:1d.0 USB controller [0c03]: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 [8086:8c26] (rev 04)
00:1f.0 ISA bridge [0601]: Intel Corporation HM86 Express LPC Controller [8086:8c49] (rev 04)
00:1f.2 SATA controller [0106]: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] [8086:8c03] (rev 04)
00:1f.3 SMBus [0c05]: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller [8086:8c22] (rev 04)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GK107M [GeForce GT 750M] [10de:0fe4] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation GK107 HDMI Audio Controller [10de:0e1b] (rev a1)
07:00.0 3D controller [0302]: NVIDIA Corporation GK107M [GeForce GT 750M] [10de:0fe4] (rev a1)
09:00.0 Ethernet controller [0200]: Qualcomm Atheros QCA8171 Gigabit Ethernet [1969:10a1] (rev 10)
0a:00.0 Network controller [0280]: Intel Corporation Centrino Wireless-N 2230 [8086:0888] (rev c4)
/usr/bin/lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 8087:07da Intel Corp.
Bus 003 Device 004: ID 1532:001f Razer USA, Ltd
Bus 003 Device 003: ID 046d:0a1f Logitech, Inc. G930
Bus 003 Device 002: ID 174f:1474 Syntek
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
/usr/sbin/dmidecode
dmidecode 2.12
SMBIOS entry point at 0x85ebef98
SMBIOS 2.7 present.
69 structures occupying 2941 bytes.
Table at 0x85EBC000.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: LENOVO
Version: 74CN35WW(V1.10)
Release Date: 07/18/2013
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 4608 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Japanese floppy for NEC 9800 1.2 MB is supported (int 13h)
Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 0.35
Firmware Revision: 0.0
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: LENOVO
Product Name: 20217
Version: Lenovo IdeaPad Y510P
Serial Number: 1003501200567
UUID: 61A2F68D-07F4-E211-BF94-28D2441CE7EB
Wake-up Type: Power Switch
SKU Number: LENOVO_BI_IDEAPAD
Family: IDEAPAD
Handle 0x0002, DMI type 2, 16 bytes
Base Board Information
Product Name: 20217
Version: 31900003WIN8 STD MLT
Serial Number: YB00992136
Asset Tag: YB00992136
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Type2 - Board Chassis Location
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 23 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
SKU Number: Not Specified
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: U3E1
Type: Central Processor
Family: Core i7
Manufacturer: Intel(R) Corporation
ID: C3 06 03 00 FF FB EB BF
Signature: Type 0, Family 6, Model 60, Stepping 3
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Core™ i7-4700MQ CPU @ 2.40GHz
Voltage: 0.8 V
External Clock: 100 MHz
Max Speed: 2400 MHz
Current Speed: 2400 MHz
Status: Populated, Enabled
Upgrade: Socket rPGA988B
L1 Cache Handle: 0x000B
L2 Cache Handle: 0x000C
L3 Cache Handle: 0x000D
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 4
Core Enabled: 4
Thread Count: 8
Characteristics:
64-bit capable
Multi-Core
Hardware Thread
Execute Protection
Enhanced Virtualization
Power/Performance Control
Handle 0x0005, DMI type 5, 24 bytes
Memory Controller Information
Error Detecting Method: None
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 8192 MB
Maximum Total Memory Size: 32768 MB
Supported Speeds:
Other
Supported Memory Types:
Other
Memory Module Voltage: Unknown
Associated Memory Slots: 4
0x0006
0x0007
0x0008
0x0009
Enabled Error Correcting Capabilities:
None
Handle 0x0006, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: DIMM0
Bank Connections: None
Current Speed: Unknown
Type: DIMM
Installed Size: 4096 MB (Single-bank Connection)
Enabled Size: 4096 MB (Single-bank Connection)
Error Status: OK
Handle 0x0007, DMI type 6, 12 bytes
Socket Designation: DIMM1
Type: DIMM
Installed Size: Not Installed
Enabled Size: Not Installed
Error Status: OK
Handle 0x0008, DMI type 6, 12 bytes
Type: DIMM
Installed Size: 8192 MB (Single-bank Connection)
Enabled Size: 8192 MB (Single-bank Connection)
Error Status: OK
Handle 0x0009, DMI type 6, 12 bytes
Socket Designation: DIMM3
Type: DIMM
Error Status: OK
Handle 0x000A, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 32 kB
Maximum Size: 32 kB
Supported SRAM Types:
Synchronous
Installed SRAM Type: Synchronous
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Data
Associativity: 8-way Set-associative
Handle 0x000B, DMI type 7, 19 bytes
Cache Information
Maximum Size: 32 kB
Synchronous
Speed: Unknown
System Type: Instruction
Handle 0x000C, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 256 kB
Maximum Size: 256 kB
Synchronous
Speed: Unknown
System Type: Unified
Handle 0x000D, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3 Cache
Configuration: Enabled, Not Socketed, Level 3
Installed Size: 6144 kB
Maximum Size: 6144 kB
Synchronous
Speed: Unknown
Associativity: 12-way Set-associative
Handle 0x000E, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: Keyboard
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: Mouse
Port Type: Mouse Port
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: J2A2
External Reference Designator: COM 1
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: J3A1
External Reference Designator: USB
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x0012, DMI type 8, 9 bytes
Port Type: USB
Handle 0x0013, DMI type 8, 9 bytes
Port Type: USB
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: J5A1
Port Type: USB
Handle 0x0015, DMI type 8, 9 bytes
Port Type: USB
Handle 0x0016, DMI type 8, 9 bytes
External Reference Designator: Network
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x0017, DMI type 8, 9 bytes
Internal Reference Designator: J9G2
Internal Connector Type: On Board Floppy
External Reference Designator: OnBoard Floppy Type
External Connector Type: None
Port Type: Other
Handle 0x0018, DMI type 8, 9 bytes
Internal Reference Designator: J7J1
Internal Connector Type: On Board IDE
External Reference Designator: OnBoard Primary IDE
Port Type: Other
Handle 0x0019, DMI type 8, 9 bytes
Internal Reference Designator: J2A1
External Reference Designator: TV OUT
External Connector Type: Mini DIN
Port Type: Video Port
Handle 0x001A, DMI type 8, 9 bytes
External Reference Designator: CRT
External Connector Type: DB-15 female
Handle 0x001B, DMI type 8, 9 bytes
Internal Reference Designator: J30
External Reference Designator: Microphone In
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x001C, DMI type 8, 9 bytes
External Reference Designator: Line In
Handle 0x001D, DMI type 8, 9 bytes
External Reference Designator: Speaker Out
Handle 0x001E, DMI type 9, 17 bytes
System Slot Information
Designation: J5C1
Type: x16 PCI Express x16
Current Usage: Available
Length: Other
Characteristics:
PME signal is supported
Hot-plug devices are supported
Bus Address: 0000:00:01.0
Handle 0x001F, DMI type 9, 17 bytes
Designation: J6C1
Type: x1 PCI Express x1
Length: Other
Characteristics:
Bus Address: 0000:00:1c.0
Handle 0x0020, DMI type 9, 17 bytes
Designation: J6C2
Length: Other
Characteristics:
Bus Address: 0000:00:1c.1
Handle 0x0021, DMI type 9, 17 bytes
Designation: J6D2
Length: Other
Characteristics:
Bus Address: 0000:00:1c.2
Handle 0x0022, DMI type 9, 17 bytes
Designation: J7C1
Length: Other
Characteristics:
Bus Address: 0000:00:1c.3
Handle 0x0023, DMI type 9, 17 bytes
Designation: J7D2
Length: Other
Characteristics:
Bus Address: 0000:00:1c.4
Handle 0x0024, DMI type 9, 17 bytes
Designation: J8C1
Length: Other
Characteristics:
Bus Address: 0000:00:1c.5
Handle 0x0025, DMI type 9, 17 bytes
Designation: J8C2
Length: Other
Characteristics:
Bus Address: 0000:00:1c.7
Handle 0x0026, DMI type 11, 5 bytes
OEM Strings
String 1: String1 for Original Equipment Manufacturer
String 2: String2 for Original Equipment Manufacturer
String 3: String3 for Original Equipment Manufacturer
String 4: String4 for Original Equipment Manufacturer
String 5: String5 for Original Equipment Manufacturer
Handle 0x0027, DMI type 12, 5 bytes
System Configuration Options
Option 1: String1 for Type12 Equipment Manufacturer
Option 2: String2 for Type12 Equipment Manufacturer
Option 3: String3 for Type12 Equipment Manufacturer
Option 4: String4 for Type12 Equipment Manufacturer
Handle 0x0028, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 4
en|US|iso8859-1
fr|CA|iso8859-1
ja|JP|unicode
zh|TW|unicode
Currently Installed Language: en|US|iso8859-1
Handle 0x0029, DMI type 15, 29 bytes
System Event Log
Area Length: 0 bytes
Header Start Offset: 0x0000
Header Length: 32 bytes
Data Start Offset: 0x0020
Access Method: General-purpose non-volatile data functions
Access Address: 0x0000
Status: Valid, Not Full
Change Token: 0x12345678
Header Format: OEM-specific
Supported Log Type Descriptors: 3
Descriptor 1: POST memory resize
Data Format 1: None
Descriptor 2: POST error
Data Format 2: POST results bitmap
Descriptor 3: Log area reset/cleared
Data Format 3: None
Handle 0x002A, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 32 GB
Error Information Handle: 0x0031
Number Of Devices: 4
Handle 0x002B, DMI type 17, 34 bytes
Memory Device
Array Handle: 0x002A
Error Information Handle: 0x002F
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: DIMM0
Bank Locator: BANK 0
Type: DDR3
Type Detail: Synchronous
Speed: 1600 MHz
Manufacturer: Unknown
Serial Number: 41431D66
Asset Tag: Unknown
Part Number: HMT451S6AFR8A-PB
Rank: 1
Configured Clock Speed: 1600 MHz
Handle 0x002C, DMI type 17, 34 bytes
Memory Device
Error Information Handle: Not Provided
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: DIMM1
Bank Locator: BANK 1
Type: Unknown
Type Detail: Unknown
Speed: Unknown
Manufacturer: Empty
Serial Number: Empty
Asset Tag: Unknown
Part Number: Empty
Rank: Unknown
Configured Clock Speed: Unknown
Handle 0x002D, DMI type 17, 34 bytes
Memory Device
Error Information Handle: 0x0030
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: DIMM1
Bank Locator: BANK 2
Type: DDR3
Speed: 1600 MHz
Serial Number: 38144DCA
Asset Tag: Unknown
Part Number: HMT41GS6AFR8A-PB
Rank: 2
Handle 0x002E, DMI type 17, 34 bytes
Memory Device
Data Width: Unknown
Form Factor: DIMM
Set: None
Locator: DIMM3
Bank Locator: BANK 3
Type: Unknown
Speed: Unknown
Manufacturer: Empty
Asset Tag: Unknown
Part Number: Empty
Rank: Unknown
Handle 0x002F, DMI type 18, 23 bytes
32-bit Memory Error Information
Type: OK
Granularity: Unknown
Operation: Unknown
Vendor Syndrome: Unknown
Memory Array Address: Unknown
Device Address: Unknown
Resolution: Unknown
Handle 0x0030, DMI type 18, 23 bytes
Type: OK
Operation: Unknown
Resolution: Unknown
Handle 0x0031, DMI type 18, 23 bytes
Type: OK
Operation: Unknown
Resolution: Unknown
Handle 0x0032, DMI type 19, 31 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x002FFFFFFFF
Range Size: 12 GB
Physical Array Handle: 0x002A
Partition Width: 4
Handle 0x0033, DMI type 20, 35 bytes
Memory Device Mapped Address
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Device Handle: 0x002B
Memory Array Mapped Address Handle: 0x0032
Partition Row Position: Unknown
Interleave Position: 1
Interleaved Data Depth: 1
Handle 0x0034, DMI type 20, 35 bytes
Ending Address: 0x001FFFFFFFF
Range Size: 8 GB
Physical Device Handle: 0x002D
Interleave Position: 2
Handle 0x0035, DMI type 21, 7 bytes
Built-in Pointing Device
Type: Touch Pad
Interface: PS/2
Buttons: 4
Handle 0x0036, DMI type 22, 26 bytes
Portable Battery
Manufacturer: -Virtual Battery 0-
Manufacture Date: 07/07/2010
Serial Number: Battery 0
Name: CRB Battery 0
Chemistry: Lithium Ion
Design Capacity: Unknown
Design Voltage: Unknown
SBDS Version: Not Specified
Maximum Error: Unknown
OEM-specific Information: 0x00000000
Handle 0x0037, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Disabled
Administrator Password Status: Disabled
Front Panel Reset Status: Disabled
Handle 0x0038, DMI type 26, 22 bytes
Voltage Probe
Description: Voltage Probe Description.
Status: Unknown
Maximum Value: Unknown
Minimum Value: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Nominal Value: Unknown
Handle 0x0039, DMI type 27, 15 bytes
Cooling Device
Type: Fan
Status: OK
Nominal Speed: 2000 rpm
Description: Cooling Device Description.
Handle 0x003A, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x003B, DMI type 39, 22 bytes
System Power Supply
Manufacturer: OEM_Define2
Serial Number: OEM_Define3
Asset Tag: OEM_Define4
Model Part Number: OEM_Define5
Revision: OEM_Define6
Max Power Capacity: 75 W
Status: Present, OK
Type: Regulator
Input Voltage Range Switching: Auto-switch
Plugged: No
Hot Replaceable: No
Cooling Device Handle: 0x0039
Handle 0x003C, DMI type 40, 18 bytes
Additional Information 1
Referenced Handle: 0x001e
Referenced Offset: 0x05
String: PCIExpressx16
Value: 0xaa
Additional Information 2
Referenced Handle: 0x0000
String: Compiler Version: VC 9.0
Value: 0x05dc
Handle 0x003D, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Hanksville Gbe Lan Connection
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:00.1
Handle 0x003E, DMI type 128, 8 bytes
OEM-specific Type
Header and Data:
80 08 3E 00 55 AA 55 AA
Strings:
Oem Test 1
Oem Test 2
Handle 0x003F, DMI type 129, 8 bytes
OEM-specific Type
Header and Data:
81 08 3F 00 01 01 02 01
Strings:
Intel_ASF
Intel_ASF_001
Handle 0x0040, DMI type 130, 20 bytes
OEM-specific Type
Header and Data:
82 14 40 00 24 41 4D 54 01 01 01 01 01 A5 1F 02
00 00 00 00
Handle 0x0041, DMI type 133, 5 bytes
OEM-specific Type
Header and Data:
85 05 41 00 01
Strings:
KHOIHGIUCCHHII
Handle 0x0042, DMI type 136, 6 bytes
OEM-specific Type
Header and Data:
88 06 42 00 FF FF
Handle 0x0043, DMI type 221, 12 bytes
OEM-specific Type
Header and Data:
DD 0C 43 00 01 01 00 01 03 00 00 00
Strings:
Reference Code - ACPI
Handle 0x0044, DMI type 127, 4 bytes
End Of Table
/sbin/modinfo nvidia | grep vermagic
Scanning kernel log files for NVRM messages:
/var/log/messages is not readable
/var/log/kernel.log is not readable
dmesg:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.11.0-12-generic (buildd@allspice) (gcc version 4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu7) ) #19-Ubuntu SMP Wed Oct 9 16:20:46 UTC 2013 (Ubuntu 3.11.0-12.19-generic 3.11.3)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-12-generic.efi.signed root=UUID=5f37d7ef-187e-48e2-96d5-f4095b8b9efd ro text
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000006efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000006f000-0x000000000006ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000070000-0x0000000000087fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000088000-0x00000000000bffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007fcaffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007fcb0000-0x00000000810affff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000810b0000-0x00000000856befff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000856bf000-0x0000000085ebefff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000085ebf000-0x0000000085fbefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000085fbf000-0x0000000085ffefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000085fff000-0x0000000085ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000086000000-0x000000008fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb00000-0x00000000feb0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffb80000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000036effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.31 by INSYDE Corp.
[ 0.000000] efi: ACPI=0x85ffe000 ACPI 2.0=0x85ffe014 SMBIOS=0x85ebef98
[ 0.000000] efi: mem00: type=3, attr=0xf, range=[0x0000000000000000-0x0000000000001000) (0MB)
[ 0.000000] efi: mem01: type=7, attr=0xf, range=[0x0000000000001000-0x000000000006f000) (0MB)
[ 0.000000] efi: mem02: type=0, attr=0xf, range=[0x000000000006f000-0x0000000000070000) (0MB)
[ 0.000000] efi: mem03: type=7, attr=0xf, range=[0x0000000000070000-0x0000000000080000) (0MB)
[ 0.000000] efi: mem04: type=3, attr=0xf, range=[0x0000000000080000-0x0000000000082000) (0MB)
[ 0.000000] efi: mem05: type=7, attr=0xf, range=[0x0000000000082000-0x0000000000088000) (0MB)
[ 0.000000] efi: mem06: type=6, attr=0x800000000000000f, range=[0x0000000000088000-0x00000000000a0000) (0MB)
[ 0.000000] efi: mem07: type=2, attr=0xf, range=[0x0000000000100000-0x00000000014f3000) (19MB)
[ 0.000000] efi: mem08: type=7, attr=0xf, range=[0x00000000014f3000-0x0000000002000000) (11MB)
[ 0.000000] efi: mem09: type=2, attr=0xf, range=[0x0000000002000000-0x00000000033f3000) (19MB)
[ 0.000000] efi: mem10: type=7, attr=0xf, range=[0x00000000033f3000-0x0000000035eec000) (810MB)
[ 0.000000] efi: mem11: type=2, attr=0xf, range=[0x0000000035eec000-0x0000000036f6e000) (16MB)
[ 0.000000] efi: mem12: type=7, attr=0xf, range=[0x0000000036f6e000-0x000000005e3bf000) (628MB)
[ 0.000000] efi: mem13: type=2, attr=0xf, range=[0x000000005e3bf000-0x000000007e0c0000) (509MB)
[ 0.000000] efi: mem14: type=4, attr=0xf, range=[0x000000007e0c0000-0x000000007e0e0000) (0MB)
[ 0.000000] efi: mem15: type=7, attr=0xf, range=[0x000000007e0e0000-0x000000007eaf7000) (10MB)
[ 0.000000] efi: mem16: type=2, attr=0xf, range=[0x000000007eaf7000-0x000000007ecb1000) (1MB)
[ 0.000000] efi: mem17: type=4, attr=0xf, range=[0x000000007ecb1000-0x000000007fcb0000) (15MB)
[ 0.000000] efi: mem18: type=0, attr=0xf, range=[0x000000007fcb0000-0x00000000810b0000) (20MB)
[ 0.000000] efi: mem19: type=7, attr=0xf, range=[0x00000000810b0000-0x00000000810bd000) (0MB)
[ 0.000000] efi: mem20: type=2, attr=0xf, range=[0x00000000810bd000-0x00000000810bf000) (0MB)
[ 0.000000] efi: mem21: type=7, attr=0xf, range=[0x00000000810bf000-0x000000008118b000) (0MB)
[ 0.000000] efi: mem22: type=1, attr=0xf, range=[0x000000008118b000-0x00000000812bf000) (1MB)
[ 0.000000] efi: mem23: type=7, attr=0xf, range=[0x00000000812bf000-0x0000000081bf8000) (9MB)
[ 0.000000] efi: mem24: type=2, attr=0xf, range=[0x0000000081bf8000-0x0000000081c02000) (0MB)
[ 0.000000] efi: mem25: type=4, attr=0xf, range=[0x0000000081c02000-0x0000000081c36000) (0MB)
[ 0.000000] efi: mem26: type=7, attr=0xf, range=[0x0000000081c36000-0x0000000081c37000) (0MB)
[ 0.000000] efi: mem27: type=4, attr=0xf, range=[0x0000000081c37000-0x0000000081cc5000) (0MB)
[ 0.000000] efi: mem28: type=7, attr=0xf, range=[0x0000000081cc5000-0x0000000081cc6000) (0MB)
[ 0.000000] efi: mem29: type=4, attr=0xf, range=[0x0000000081cc6000-0x0000000081cc7000) (0MB)
[ 0.000000] efi: mem30: type=7, attr=0xf, range=[0x0000000081cc7000-0x0000000081cc8000) (0MB)
[ 0.000000] efi: mem31: type=4, attr=0xf, range=[0x0000000081cc8000-0x0000000081dda000) (1MB)
[ 0.000000] efi: mem32: type=7, attr=0xf, range=[0x0000000081dda000-0x0000000081ddb000) (0MB)
[ 0.000000] efi: mem33: type=4, attr=0xf, range=[0x0000000081ddb000-0x0000000082f37000) (17MB)
[ 0.000000] efi: mem34: type=3, attr=0xf, range=[0x0000000082f37000-0x0000000082f57000) (0MB)
[ 0.000000] efi: mem35: type=4, attr=0xf, range=[0x0000000082f57000-0x0000000082fd7000) (0MB)
[ 0.000000] efi: mem36: type=3, attr=0xf, range=[0x0000000082fd7000-0x0000000082ff7000) (0MB)
[ 0.000000] efi: mem37: type=4, attr=0xf, range=[0x0000000082ff7000-0x0000000083049000) (0MB)
[ 0.000000] efi: mem38: type=7, attr=0xf, range=[0x0000000083049000-0x000000008304b000) (0MB)
[ 0.000000] efi: mem39: type=4, attr=0xf, range=[0x000000008304b000-0x000000008304c000) (0MB)
[ 0.000000] efi: mem40: type=7, attr=0xf, range=[0x000000008304c000-0x0000000083053000) (0MB)
[ 0.000000] efi: mem41: type=4, attr=0xf, range=[0x0000000083053000-0x000000008306b000) (0MB)
[ 0.000000] efi: mem42: type=7, attr=0xf, range=[0x000000008306b000-0x000000008306c000) (0MB)
[ 0.000000] efi: mem43: type=4, attr=0xf, range=[0x000000008306c000-0x0000000083073000) (0MB)
[ 0.000000] efi: mem44: type=7, attr=0xf, range=[0x0000000083073000-0x0000000083075000) (0MB)
[ 0.000000] efi: mem45: type=4, attr=0xf, range=[0x0000000083075000-0x000000008309f000) (0MB)
[ 0.000000] efi: mem46: type=7, attr=0xf, range=[0x000000008309f000-0x00000000830a2000) (0MB)
[ 0.000000] efi: mem47: type=4, attr=0xf, range=[0x00000000830a2000-0x00000000831dd000) (1MB)
[ 0.000000] efi: mem48: type=3, attr=0xf, range=[0x00000000831dd000-0x00000000831ea000) (0MB)
[ 0.000000] efi: mem49: type=4, attr=0xf, range=[0x00000000831ea000-0x000000008320b000) (0MB)
[ 0.000000] efi: mem50: type=7, attr=0xf, range=[0x000000008320b000-0x000000008320d000) (0MB)
[ 0.000000] efi: mem51: type=4, attr=0xf, range=[0x000000008320d000-0x00000000852bf000) (32MB)
[ 0.000000] efi: mem52: type=7, attr=0xf, range=[0x00000000852bf000-0x00000000852c4000) (0MB)
[ 0.000000] efi: mem53: type=3, attr=0xf, range=[0x00000000852c4000-0x00000000856bf000) (3MB)
[ 0.000000] efi: mem54: type=5, attr=0x800000000000000f, range=[0x00000000856bf000-0x00000000858bf000) (2MB)
[ 0.000000] efi: mem55: type=6, attr=0x800000000000000f, range=[0x00000000858bf000-0x0000000085abf000) (2MB)
[ 0.000000] efi: mem56: type=0, attr=0xf, range=[0x0000000085abf000-0x0000000085ebf000) (4MB)
[ 0.000000] efi: mem57: type=10, attr=0xf, range=[0x0000000085ebf000-0x0000000085fbf000) (1MB)
[ 0.000000] efi: mem58: type=9, attr=0xf, range=[0x0000000085fbf000-0x0000000085fff000) (0MB)
[ 0.000000] efi: mem59: type=4, attr=0xf, range=[0x0000000085fff000-0x0000000086000000) (0MB)
[ 0.000000] efi: mem60: type=7, attr=0xf, range=[0x0000000100000000-0x000000036f000000) (9968MB)
[ 0.000000] efi: mem61: type=0, attr=0x0, range=[0x00000000000a0000-0x00000000000c0000) (0MB)
[ 0.000000] efi: mem62: type=0, attr=0x0, range=[0x0000000086000000-0x0000000090000000) (160MB)
[ 0.000000] efi: mem63: type=11, attr=0x8000000000000001, range=[0x00000000e0000000-0x00000000f0000000) (256MB)
[ 0.000000] efi: mem64: type=11, attr=0x8000000000000001, range=[0x00000000feb00000-0x00000000feb10000) (0MB)
[ 0.000000] efi: mem65: type=11, attr=0x8000000000000001, range=[0x00000000fec00000-0x00000000fec01000) (0MB)
[ 0.000000] efi: mem66: type=11, attr=0x8000000000000001, range=[0x00000000fed00000-0x00000000fed1c000) (0MB)
[ 0.000000] efi: mem67: type=11, attr=0x8000000000000000, range=[0x00000000fed1c000-0x00000000fed20000) (0MB)
[ 0.000000] efi: mem68: type=11, attr=0x8000000000000001, range=[0x00000000fed20000-0x00000000fee01000) (0MB)
[ 0.000000] efi: mem69: type=11, attr=0x8000000000000000, range=[0x00000000ffb80000-0x0000000100000000) (4MB)
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: LENOVO 20217/20217, BIOS 74CN35WW(V1.10) 07/18/2013
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] No AGP bridge found
[ 0.000000] e820: last_pfn = 0x36f000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E7FFF write-protect
[ 0.000000] E8000-EFFFF write-combining
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7F80000000 write-back
[ 0.000000] 1 base 0080000000 mask 7FFC000000 write-back
[ 0.000000] 2 base 0084000000 mask 7FFE000000 write-back
[ 0.000000] 3 base 00FF800000 mask 7FFF800000 write-protect
[ 0.000000] 4 base 0100000000 mask 7F00000000 write-back
[ 0.000000] 5 base 0200000000 mask 7E00000000 write-back
[ 0.000000] 6 base 036F000000 mask 7FFF000000 uncachable
[ 0.000000] 7 base 0370000000 mask 7FF0000000 uncachable
[ 0.000000] 8 base 0380000000 mask 7F80000000 uncachable
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820: last_pfn = 0x86000 max_arch_pfn = 0x400000000
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ffff880000082000] 82000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] BRK [0x02fd1000, 0x02fd1fff] PGTABLE
[ 0.000000] BRK [0x02fd2000, 0x02fd2fff] PGTABLE
[ 0.000000] BRK [0x02fd3000, 0x02fd3fff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x36ee00000-0x36effffff]
[ 0.000000] [mem 0x36ee00000-0x36effffff] page 2M
[ 0.000000] BRK [0x02fd4000, 0x02fd4fff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x36c000000-0x36edfffff]
[ 0.000000] [mem 0x36c000000-0x36edfffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x300000000-0x36bffffff]
[ 0.000000] [mem 0x300000000-0x33fffffff] page 1G
[ 0.000000] [mem 0x340000000-0x36bffffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x7fcaffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0x7fbfffff] page 2M
[ 0.000000] [mem 0x7fc00000-0x7fcaffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x810b0000-0x856befff]
[ 0.000000] [mem 0x810b0000-0x811fffff] page 4k
[ 0.000000] [mem 0x81200000-0x855fffff] page 2M
[ 0.000000] [mem 0x85600000-0x856befff] page 4k
[ 0.000000] BRK [0x02fd5000, 0x02fd5fff] PGTA
Any Idea?
I’ve got the same laptop with what sounds like the same problem, though I’m running Arch with kernel 3.11.6-1 and nvidia 325.15-10.
I can boot to a prompt just fine, but as soon as I try to start a desktop environment I get some errors about not being able to find a screen or something like that. I didn’t have any SLI configuration set and even tried it with the second GPU removed (modular on this model). I don’t have access to the system at the moment but can gather information and post further details if it will be helpful.
ubuntu 13.10 works just fine… if you need any info from me please let me know.
only thing I can remember at this moment, i had to enable legacy boot support in bios to boot into graphics (sorry for noob language, I’m new to linux but I want to learn)
Karagra, I think you have uefi mode installed OS, Is the issue reproduce in legacy bios mode installed OS?
I have same problem, but with dual gt755m, same y510p laptop. Running system with legacy mode not helped.
It’s mormal, that lspci displays only one VGA device, but nvidia control panel and clinfo displays two?
I have a Lenovo IdeaPad Y510P with Ubuntu 14.04 LTS 64 bit. I get the same error messages. Lspci | grep VGA only displays one nVidia Geforce GT 755M GPU. I installed the nVidia 331.38 graphics driver by searching for additional drivers and it worked. However, the second nVidia Geforce GT 755M GPU is not detected and SLi does not work on the second screen. What is going on here? How can I get both of them to work in Ubuntu 14.04 LTS 64 bit GNU/Linux?
Update:
I have Legacy Boot with Legacy First enabled in my BIOS.
How do I upload my nVidia bug report here?
nvidia-bug-report.log.gz (350 KB)
Is someone at nVidia GNU/Linux taking a look at these issues and is there going to be a fix to this problem to enable nVidia SLi for mobile GPUs or not? It’s been 8 months and counting so far.
I can confirm the issue, there’s not a single driver release since the added support for GT 755M that works with SLI (tested personally). My system is Slackware64 14.1 with a 3.15.0 kernel and SLI isn’t working under Legacy BIOS or UEFI. However under Windows it’s working perfectly fine (shocker). Someone stated that the Linux Driver team is significantly smaller than the Windows driver team and I understand that, however mind that Unreal engine (among a dozen other things) is coming to Linux natively and it’s going to be neat if we can actually use our video card duo on our OS of choice.
I just called nVidia Corporation and Monsoor told me that they do support nVidia SLi for mobile GPUs for the Lenovo IdeaPad Y510P notebook PC in GNU/Linux. He said that he will e-mail me detailed instructions on how to get it to work properly in a few minutes. He also said that I can call nVidia Corporation for technical support if I run into a problem. It is supported and as soon as I get the instructions, I will post it here.
We shall see if this works or not.
http://us.download.nvidia.com/XFree86/Linux-x86_64/340.17/README/sli.html
He sent me this document. He told me that I have to rely on the nVidia GNU/Linux team for support here on this forum.
I get this error:
wellywu@IDEAPADY510P:~$ lspci | grep -i vga
01:00.0 VGA compatible controller: NVIDIA Corporation GK107M [GeForce GT 755M] (rev a1)
wellywu@IDEAPADY510P:~$ lspci -t
-[0000:00]-±00.0
±01.0-[01-06]–±00.0
| -00.1
±01.1-[07]----00.0
±14.0
±16.0
±1a.0
±1b.0
±1c.0-[08]----00.0
±1c.4-[09]----00.0
±1d.0
±1f.0
±1f.2
-1f.3
It’s not detecting my second nVidia Geforce GT 755M GPU. How do I fix this problem? I haven’t tried the instructions yet as I’m not sure if they will work if the second GPU is not detected.
How do I get nVidia SLi to work with my Lenovo IdeaPad Y510P?
It looks like the nVidia 340.17 Beta graphics driver for GNU/Linux supports SLi and multi-GPU frame rendering. It doesn’t require a runlevel=1 to install it. I’m not going to attempt this until someone else does. Can someone at nVidia test this with a Lenovo IdeaPad Y510P and Ubuntu 14.04 LTS 64 bit GNU/Linux? Thanks.
Is this the VBIOS update that is necessary for the Lenovo IdeaPad Y510P:
I called Lenovo Idea technical support and they told me that they do not support GNU/Linux distributions for their Lenovo IdeaPad Y510P notebook PC. They only support Microsoft Windows with the specific version that was pre-installed on the Y510P. So, they have no information about a VBIOS update to enable the second nVidia Geforce GT 750/755M 2 GB VRAM GPU.
