fiepi
November 13, 2022, 6:51am
21
mpv not work on 525.53 driver
wayland
~/Videos » mpv --msg-level=vo=v demo-4k.mp4
(+) Video --vid=1 (*) (h264 3840x2160 60.000fps)
(+) Audio --aid=1 (*) (aac 2ch 48000Hz)
File tags:
Date: 2022
[vo/gpu] Probing for best GPU context.
[vo/gpu/opengl] Initializing GPU context 'wayland'
[vo/gpu/wayland] Registered for protocol wl_compositor
[vo/gpu/wayland] Registered for protocol wl_shm
[vo/gpu/wayland] Registered for protocol wl_output
[vo/gpu/wayland] Registered for protocol wl_data_device_manager
[vo/gpu/wayland] Registered for protocol xdg_wm_base
[vo/gpu/wayland] Registered for protocol wl_seat
[vo/gpu/wayland] Registered for protocol wp_presentation
[vo/gpu/wayland] GNOME's wayland compositor lacks support for the idle inhibit protocol. This means the screen can blank during playback.
[vo/gpu/wayland] Compositor doesn't support the zxdg_decoration_manager_v1 protocol!
[vo/gpu/wayland] Compositor doesn't support the zwp_idle_inhibit_manager_v1 protocol!
[vo/gpu/opengl] EGL_VERSION=1.5
[vo/gpu/opengl] EGL_VENDOR=NVIDIA
[vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL_ES OpenGL
[vo/gpu/opengl] Trying to create Desktop OpenGL context.
[vo/gpu/wayland] GL_VERSION='4.4.0 NVIDIA 525.53'
[vo/gpu/wayland] Detected desktop OpenGL 4.4.
[vo/gpu/wayland] GL_VENDOR='NVIDIA Corporation'
[vo/gpu/wayland] GL_RENDERER='NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2'
[vo/gpu/wayland] GL_SHADING_LANGUAGE_VERSION='4.40 NVIDIA via Cg compiler'
[vo/gpu] Testing FBO format rgba16f
[vo/gpu] Using FBO format rgba16f.
[vo/gpu/wayland] Registered output CSO 0x1609 (0x5):
[vo/gpu/wayland] x: 0px, y: 0px
[vo/gpu/wayland] w: 2560px (340mm), h: 1600px (220mm)
[vo/gpu/wayland] scale: 2
[vo/gpu/wayland] Hz: 165.018000
[vo/gpu] Resize: 0x0
[vo/gpu] Loading hwdec driver 'vaapi-egl'
[vo/gpu/vaapi-egl] using VAAPI EGL interop
[vo/gpu/vaapi-egl] Trying to open a x11 VA display...
[vo/gpu/vaapi-egl] Trying to open a wayland VA display...
x11
~ » mpv --msg-level=vo=v ~/Videos/demo-4k.mp4
File tags:
Date: 2022
[vo/gpu/opengl] Initializing GPU context 'x11egl'
[vo/gpu/x11] X11 opening display: :0
[vo/gpu/x11] Display 0 (DP-4): [0, 0, 2560, 1600] @ 165.018764 FPS
[vo/gpu/x11] Current display FPS: 165.018764
[vo/gpu/opengl] Choosing visual EGL config 0x28, visual ID 0x2b
[vo/gpu/opengl] GL_VERSION='4.4.0 NVIDIA 525.53'
[vo/gpu/opengl] Detected desktop OpenGL 4.4.
[vo/gpu/opengl] GL_VENDOR='NVIDIA Corporation'
[vo/gpu/opengl] GL_RENDERER='NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2'
[vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='4.40 NVIDIA via Cg compiler'
[vo/gpu] Assuming 165.018764 FPS for display sync.
amrits
November 17, 2022, 6:23am
23
Can you please try with flag --hwdec=nvdec. There are no failures for hardware decoding or mpv with --hwdec=nvdec on my test system.
fiepi
November 17, 2022, 12:23pm
24
amrits
November 21, 2022, 9:40am
26
@fiepi
Can we close bug if issue if fixed at your end with mpv 0.35.0
@Lastique
Thanks for the pointer.
@amrits I tried mpv 0.35. Apparently, the official released binary is not compiled with NVDEC as it doesn’t recognize hwdec=nvdec and decodes video in software. At least, that’s the case on X11. If @fiepi tested that binary, I don’t think he actually tested the problem. I did not compile mpv from source, so I cannot tell if it fixes it. But given the other threads I pointed to earlier, and that e.g. Firefox also doesn’t work, I doubt it.
fiepi
November 21, 2022, 10:33am
28
~ » mpv --msg-level=vo=v --hwdec=nvdec ~/Videos/demo-4k.mp4
File tags:
Date: 2022
[vo/gpu/wayland] Registered for protocol wl_subcompositor
[vo/gpu/wayland] Registered for protocol wp_viewporter
[vo/gpu/wayland] Registered for protocol zwp_linux_dmabuf_v1
[vo/gpu/wayland] Loaded extension GL_KHR_debug.
[vo/gpu] Loading hwdec drivers for format: 'cuda'
[vo/gpu] Loading hwdec driver 'cuda'
Using hardware decoding (nvdec).
AO: [pipewire] 48000Hz stereo 2ch floatp
VO: [gpu] 3840x2160 cuda[nv12]
[vo/gpu] reconfig to 3840x2160 cuda[nv12] bt.601/bt.601-525/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vo/gpu/wayland] Reconfiguring!
[vo/gpu] Resize: 3840x2160
[vo/gpu] Window size: 3840x2160 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video source: 3840x2160 (1:1)
[vo/gpu] Video display: (0, 0) 3840x2160 -> (0, 0) 3840x2160
[vo/gpu] Video scale: 1.000000/1.000000
[vo/gpu] OSD borders: l=0 t=0 r=0 b=0
[vo/gpu] Video borders: l=0 t=0 r=0 b=0
[vo/gpu/wayland] Handling resize on the egl side
[vo/gpu] Reported display depth: 8
[vo/gpu] Dither to 8.
[vo/gpu/wayland] Resizing due to xdg from 3840x2160 to 2560x1440
[vo/gpu/wayland] Received a new DND offer. Releasing the previous offer.
[vo/gpu] Resize: 2560x1440
[vo/gpu] Window size: 2560x1440 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video display: (0, 0) 3840x2160 -> (0, 0) 2560x1440
[vo/gpu] Video scale: 0.666667/0.666667
AV: 00:00:00 / 00:00:30 (0%) A-V: 0.013
[vo/gpu/wayland] Surface entered output CSO 0x1609 (0x5), scale = 2
[vo/gpu] Assuming 165.018000 FPS for display sync.
AV: 00:00:00 / 00:00:30 (3%) A-V: 0.016 Dropped: 1
[vo/gpu] Reallocating OSD texture to 4096x512.
AV: 00:00:02 / 00:00:30 (7%) A-V: -0.000 Dropped: 2
AV: 00:00:03 / 00:00:30 (13%) A-V: -0.002 Dropped: 2
AV: 00:00:29 / 00:00:30 (100%) A-V: 0.000 Dropped: 2
Exiting... (End of file)
[vo/gpu/wayland] Deregistering output CSO 0x1609 (0x5)
fiepi
November 21, 2022, 10:36am
29
Ok, then ArchLinux packages were built with NVDEC. Thanks for clarifying.
amrits
November 28, 2022, 12:28pm
31
@fiepi
If everything works at your end, shall we close this thread ?
