Operating System:
Windows
Application
USD Composer
GPU Hardware:
30 series
Work Flow: Enabled to omni.kit.livestream.webrtc extension in USD composer and added the IP of hosting system in the URL
Main Issue: Not able to stream the USD composer, on clicking the button, app appears blank.
URL is working in hosting system but not in other system with same network
Error Code:
Hi there and thanks for asking this question. This is not working because this is not the new way of doing streaming.
First follow these videos to make sure you have the latest version
How to Get Started Building Custom Digital Twin Applications - YouTube
Then follow this for specifically streaming. This is the old. The new method is here. This video is a little older, showing kit 106.5, not kit 107.3, so you can ignore the “-d” thing.
Hi Richard,
Thank you for the response. I will look into it.
Just for you to know i used the following method of Streaming over Local Network:
WebRTC Browser Client — Omniverse Extensions
Yes that is old now. Please ignore.
Thank you, Richard. This has been very helpful. I’m now able to stream USD Composer on my system. Could you please guide me on how to stream it on another system over the local network as well as the different network?
