I recently generated a new data set but have a strange issue.
only some, and I don’t know how many yet, xml files throw errors.
The weird thing is all I have to do to fix it is open the xml in notepad++ and save and that is it!
unfortuntely there are 14k files and I have no idea how many I have to do this to, so far I have done 100 lol
But basically I am just running it, waiting for error, open, save, close, run, repeat!
I would love if someone could tell me what the difference is between these two xml files? I could fix this then en mass with a script…
first xml produces the following error:
File "train_ssd.py", line 368, in <module>
device=DEVICE, debug_steps=args.debug_steps, epoch=epoch)
File "train_ssd.py", line 132, in train
for i, data in enumerate(loader):
File "C:\Users\muayt\.virtualenvs\jetson_dev-V1CBiXeI\lib\site-packages\torch\utils\data\dataloader.py", line 517, in __next__
data = self._next_data()
File "C:\Users\muayt\.virtualenvs\jetson_dev-V1CBiXeI\lib\site-packages\torch\utils\data\dataloader.py", line 557, in _next_data
data = self._dataset_fetcher.fetch(index) # may raise StopIteration
File "C:\Users\muayt\.virtualenvs\jetson_dev-V1CBiXeI\lib\site-packages\torch\utils\data\_utils\fetch.py", line 44, in fetch
data = [self.dataset[idx] for idx in possibly_batched_index]
File "C:\Users\muayt\.virtualenvs\jetson_dev-V1CBiXeI\lib\site-packages\torch\utils\data\_utils\fetch.py", line 44, in <listcomp>
File "C:\Users\muayt\.virtualenvs\jetson_dev-V1CBiXeI\lib\site-packages\torch\utils\data\dataset.py", line 219, in __getitem__
return self.datasets[dataset_idx][sample_idx]
File "F:\Work\Highlight\TF\jetson_dev\jetson-inference-master\python\training\detection\vision\datasets\voc_dataset.py", line 58, in __getitem__
boxes, labels, is_difficult = self._get_annotation(image_id)
File "F:\Work\Highlight\TF\jetson_dev\jetson-inference- master\python\training\detection\vision\datasets\voc_dataset.py", line 118, in _get_annotation
class_name = object.find('name').text.strip() #.lower().strip()
AttributeError: 'NoneType' object has no attribute 'strip'
second xml file loads fine…
file1 (error): Deleted
fil 2 (no error): Deleted
