Weston desktop issues
Hi, everyone,
I used Weston desktop on jetson xavier nx, and launch Weston using the following command
sudo weston-lanch -u `user’s name’
And i add xwayland=true at weston.ini in the core section.
After, the Weston launch normally, but when i run a Qt simple program,
it shows
libEGL warning: MESA-LOADER: failed to open tegra-udrm: /usr/lib/dri/tegra-udrm_dri.so: cannot open shared object file: No such file or directory
And the terminal log is shows
src/tegra_gbm.c:98: GBM-DRV error (tegra_gbm_bo_create): DRM_IOCTL_TEGRA_GEM_CREATE failed (size=131072)
src/tegra_gbm.c:98: GBM-DRV error (tegra_gbm_bo_create): DRM_IOCTL_TEGRA_GEM_CREATE failed (size=5636096)
src/tegra_gbm.c:98: GBM-DRV error (tegra_gbm_bo_create): DRM_IOCTL_TEGRA_GEM_CREATE failed (size=5373952)
So where is file tegra-udrm_dri.so
Best regards,
Ultwcz1997
Would like to know which Jetpack release you are using. Do you use 4.6.4 or 5.1.2?
Yes, Jetpack 5.1.1 R35.3.1
We have the section for running Weston:
Weston (Wayland) — Jetson Linux Developer Guide documentation
Please check and make sure you have followed the steps. We would expect it works fine by executing the steps one by one.
Hi @DaneLLL,
I want to run an X app at Weston and followed the steps, i used weston-launch as a non-root user, and modified weston.ini, added xwayland=true, but i could not find the shared object, i think it was compile option not enabled.
So i compile the complete Weston-9 for my NX, and when i used launch weston-launch, it shows
weston-launch must be run from a virtual terminal
So i could only use
Finally, the Weston desktop launched successfully and ran gnome-* normally, but when i ran my Qt program, it shows
Could you apply the environment described in developer guide to your use-case? This is a tested setup and it would be great if you can develop your use-case based on it. It is possible other use-cases may not work properly.
Hi @DaneLLL,
If i apply the environment described in the developer guide to my use-case, it can not work, because my app needs X service but it has not found xwayland.so
