Hello ,
I can’t lanch weston …
I type the commands following the “NVIDIA DRIVE Software Development Guide”.
these are the logs:
nvidia@tegra-ubuntu:/usr/local/driveix-2.3/bin$ sudo su
root@tegra-ubuntu:/usr/local/driveix-2.3/bin# weston
Date: 2021-06-14 CEST
[12:28:19.612] weston 3.0.0
http://wayland.freedesktop.org
Bug reports to: https://bugs.freedesktop.org/enter_bug.cgi?product=Wayland&component=weston&version=3.0.0
Build: 3.0.0-dirty configure.ac: bump to version 3.0.0 for the official release (2017-08-08 11:46:14 -0700)
[12:28:19.612] Command line: weston
[12:28:19.612] OS: Linux, 4.14.102-rt53-tegra, #1 SMP PREEMPT RT Fri Sep 20 16:23:45 PDT 2019, aarch64
[12:28:19.613] Using config file ‘/root/.config/weston.ini’
[12:28:19.613] Output repaint window is 7 ms maximum.
[12:28:19.613] Loading module ‘/usr/local/lib/weston/x11-backend.so’
[12:28:19.613] Failed to load module: /usr/local/lib/weston/x11-backend.so: cannot open shared object file: No such file or directory
[12:28:19.613] fatal: failed to create compositor backend
thank you for your help.
