What are the software differences between the OEM DGX/GB10 boxes?
Do they run the same OS or are the others running a stock environment?
Is there a software pack that loads all the same tools on the 3P boxes if they don’t run the NVIDIA OS?
All OEM versions are equipped with the same OS, only with minor cosmetic changes.
These systems are also compatible - you can connect different OEM versions or even DGX Spark in a two-node cluster.
