Can anyone tell me what is the difference between these 2?
That devkit version is Orin Nano with sdcard slot on it.
The one beneath is Orin Nano module without sdcard slot.
Is there any change in system image for these two?
Also, i had installed Jetpack 5.1.3 earlier and sudo /opt/nvidia/jetson-io/jetson-io.py was crashing now i installed 5.1.2 and it is working file.
The BSP flashed to these two board are slightly different.
Okay thanks,
I flashed the non dev kit version, it works fine. Will it be a problem later?
Actually the flash tool itself will automatically use the correct file to flash.
That option on the SDKM GUI is kind of dummy…
