I have had Jetson products for a while and I have installed various software packages on them. I want to update some of the installed software but I don’t know which version to select as they are based on Jetson Jetpack versions. How do I figure out which version I have installed?
I know how to figure out which CUDA version I have installed through “nvidia-smi”. I just don’t know about Jetpack versions.
Hi robotsgotme, for newer versions of JetPack, you can check the L4T version (which corresponds to JetPack version) with the following command:
$ dpkg-query --show nvidia-l4t-core
For older versions of JetPack-L4T, look at the top of the file /etc/nv_tegra_release
You can determine the JetPack version from the L4T version by cross-referencing against this page:
https://developer.nvidia.com/embedded/jetpack-archive
Jetson doesn’t support nvidia-smi, as it uses an integrated GPU with a different userspace driver than the discrete GPUs.
However you can still check CUDA version by running ‘nvcc --version’ or deviceQuery sample.
