Checking Jetpack Version on Jetson Nano
Hi, I have bought a Jetson Nano recently.
I have flashed OS Image on a SD Card and then booted my Nano from SD card.
I also have Jetson TX2 and flashed jetpack many times using usual approach of downloading jetpack on a ubuntu host machine, run jetpack on host machine and flash TX2.
My problem is that :
  1. I want to know which jetpack version has been installed on my Nano?
  2. And why Argus libraries and samples are not present on my Nano ?
Hi shivkumar4680, you can check the L4T version (which corresponds to JetPack version) by running the following:
$ dpkg-query --show nvidia-l4t-core
nvidia-l4t-core 32.3.1-20191209225816
For example, L4T 32.3.1 corresponds to JetPack 4.3.
Have you checked under /usr/src/jetson_multimedia_api for the samples/headers? And the libraries should be at /usr/lib/aarch64-linux-gnu/tegra
Simpler alternative is command:
$ apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.6-b199
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.6-b199), nvidia-opencv (= 4.6-b199), nvidia-cudnn8 (= 4.6-b199), nvidia-tensorrt (= 4.6-b199), nvidia-visionworks (= 4.6-b199), nvidia-container (= 4.6-b199), nvidia-vpi (= 4.6-b199), nvidia-l4t-jetson-multimedia-api (>> 32.6-0), nvidia-l4t-jetson-multimedia-api (<< 32.7-0)
