i already setup rtsp type 4 and attach-sys-ts-as-ntp=0,
but msgconv timestamp is wrong 8 hours with computer time or camera time.
what 's problem?
thank you!
what 's problem?
thank you!
For reference, please share the information:
• DeepStream Version
• TensorRT Version
jetson nx and deepstream-5.1
thanks
For reference, please share your command line. And do you check and confirm if camera and machine are both synced to NTP server or not?
hi,
it is test5 run command normally, but run at docker and time is 8 hours lately, i tried by 12 and 24 format both is same result 8 hours lately.
if i run at my NX, stamp will be correct with my device.
IP camera yes by NTP, but how check my machine is NTP or not?
thank you!
For NTP timestamp we have guidance in
NTP Timestamp in DeepStream — DeepStream 5.1 Release documentation
Please take a look.
Not sure but do you mean you only hit the issue in docker? If you directly(without docker) run deepstream-test5 on Xavier NX, the issue is not seen?
yes without docker timestamp is right.
We would need to reproduce the issue and then do investigation. Please share steps so that we can run deepstream-test5(or test4) to reproduce the issue.
yes i have solved that,
problem is caused by docker run universal time and we need CST time in china, they are different 8 hours.
and i tried to bind local timezone at my docker file, deepstream can work by correct timezone right now, i think this is a easier way for docker running deepstream.
thank you
