When output-tensor-meta=1, how to know if it is a secondary-reinfer-interval section
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version
Rather than using a separate Parser function, I am going to set output-tensor-meta to 1 and then parse it in pad_probe_handler.
However, I want to set the secondary-reinfer-interval value to more than 0. Is there a tool like bInferDone that can be found in pad_probe_handler in Sgie?
Is your sgie model a Detector or a Classifier?
Classifier!
Do I need to modify nvinfer code?
Like the topic you filled before 272292, the classifier does not support that currently. We’ll add that in a future version.
