lvision@lvisoin-AGX-Xavier:/usr/lib$ jetson_release -v
- NVIDIA Jetson AGX Xavier [16GB]
* Jetpack 4.5.1 [L4T 32.5.1]
* NV Power Mode: MAXN - Type: 0
* jetson_stats.service: active
- Board info:
* Type: AGX Xavier [16GB]
* SOC Family: tegra194 - ID:25
* Module: P2888-0001 - Board: P2822-0000
* Code Name: galen
* CUDA GPU architecture (ARCH_BIN): 7.2
* Serial Number: 1421720004151
- Libraries:
* CUDA: 10.2.89
* cuDNN: 8.0.0.180
* TensorRT: 7.1.3.0
* Visionworks: 1.6.0.501
* OpenCV: 4.1.1 compiled CUDA: NO
* VPI: ii libnvvpi1 1.0.15 arm64 NVIDIA Vision Programming Interface library
* Vulkan: 1.2.70
- jetson-stats:
* Version 3.1.0
* Works on Python 3.6.9
It looks the default OpenCV is NOT compiled with CUDA?
hmmmmm…
Cheers
Please find the VisionWorks source in the below folder:
/usr/share/visionworks/sources
If you want an OpenCV with GPU support, you can build it from source with the following script:
system
Closed
5
