Hi, I need help programming Vision on this the NVidia JEtson Tx1, Where should I start? I have the board and the repos and files for CUDA and VisionWorks, I dont know what to do though.
Hi itsnotsnehal,
Have you installed VisionWorks ad CUDA?
If no, please install it via JetPack directly:
Not sure what you want to implement, in general, for VisionWorks → CUDA sample, please check our CUDA Layer Object Tracker Sample App example, you can find our example at ‘/usr/share/visionworks/sources/samples/object_tracker_nvxcu/’.
Hi Kayccc,
I am new also.
I do the following
sudo make
in ‘/usr/share/visionworks/sources/samples/object_tracker_nvxcu/’.
how to execute the result?
I go obj direction,all are *.o file. Which is the execution file?
Thanks,
David
I run the following command :
./nvx_sample_object_tracker_nvxcu
in /usr/share/visionworks/sources/bin/aarch64/linux/release$
You can compile VisionWorks with these command:
/usr/share/visionworks/sources/install-samples.sh ~/
cd ~/VisionWorks-<visworks_ver>-Samples/
make -j4
This information can be found in our readme shared here:
I am trying to get the board to recognize apiece of tape. Based on the the of the tape and the input value, the robot can recognize an object from a distance and what to do. What must I do in order to perform this action.
To begin with, it’s recommended to check our webinar first:
[url]NVIDIA Webinar — Breaking New Frontiers in Robotics and Edge Computing with AI - Jetson TX2 - NVIDIA Developer Forums
