Whether jetson tx2 can connect and process multiple audio input data at the same time
I would like to ask whether jetson tx2 can connect and process multiple audio input data at the same time. If multi-broadcasting input can be supported, what connection method is supported?
There are several audio inputs:
You may check which one fits your usecase first.
i will check, thank you for your help
