Whether wake up Jetson Tx2 by hardware?
Try looking at Ubuntu’s method of WakeOnLan you could use your ethernet to wake up your device
Unfortunately, the ethernet PHY BCM89610 in TX2 doesn’t support WOL (a bit of the history).
Hi, did you try short pressing power on button?
Hi
Yes,it’s work. the system can be waked up by shorting pressing power on button.pin B48 is describled SYS_WAKE#.
Whether this pin can wake up system?
Pin 48 is only for TX2i module.
