I use the I2C and I2S pins in the extended 40pin pins to connect to the wm8960 chip module on the Orin nano development board.I can confirm that the WM8960 module is no problem because it was tested on a Raspberry Pi. I asked the manufacturer of the wm8960 module this question, and they replied that it may be due to the weak output capacity of the Orin nano 40pin pin, so I will confirm with you. Also, is there any other way to use wm8960 on an Orin nano board?
You may need to probe signal to confirm the device ack for the i2c command.
