Is it not the case that LDGSTS.E.BYPASS is a variant of LDG that transfers data directly to shared memory? Which indicates that LDGDEPBAR is there for a reason. Why do you want to remove it?
I may well be misunderstanding the situation, but as this appears to involve global->shared transfer, you could be seeing impact as outlined here:
" For compute capability 8.x, the pipeline mechanism is shared among CUDA threads in the same CUDA warp. This sharing causes batches of memcpy_async to be entangled within a warp, which can impact performance under certain circumstances."
