Why does my batchsize affect the output of my inference function?
Why can my inference function output more than 200 results when my batch_size is 1, but when I increase my batch_size, my inference results are extremely reduced, and even when I set the batch_size to 128, I can only output one result. Inference result, but it is worth noting that this inference result is the same as the first inference result when batch_size is 1
this is the inference code:
def slide_batches_inference(image_array_batches:np.ndarray ,img_size)->np.ndarray:
“”"推理一个小batch的窗口图像
Args:
    image_array_batches (np.ndarray): [Batch, 1, img_size, img_size] (128,1,1024,1024)的图像
    model: 寒武纪的magic model
    img_size: 推理的图像尺寸
Returns:
    preds (np.ndarray): 模型输出文件,如果是yolov8 obb的话,为 [Batch, 20, 21504], 然后再去做 NMS 后处理
preprocessed_image_array_batches = img_batches_preprocess(image_array_batches, normalization=True)
inputs = preprocessed_image_array_batches # 存了当前 batch 要推理的数据 (batch_size, 1, 1024, 1024)
logger = trt.Logger(trt.Logger.WARNING)
runtime = trt.Runtime(logger)
with open("/JHC/yolov8m_planeship_hbb.plan", "rb") as f:
    model_data = f.read()
engine = runtime.deserialize_cuda_engine(model_data)
创建执行上下文
context = engine.create_execution_context()
# context = engine.create_execution_context()
定义输入和输出大小
input_size = [batch_size, 1, 1024, 1024]
output_size = [image_array_batches.shape[0], 19, 21504]
计算缓冲区大小
input_buffer_size = int(np.prod(input_size) * np.float32().nbytes)
output_buffer_size = int(np.prod(output_size) * np.float32().nbytes)
分配缓冲区
input_buffer = cuda.mem_alloc(input_buffer_size)
output_buffer = cuda.mem_alloc(output_buffer_size)
获取输入和输出张量的名称
input_name = engine.get_tensor_name(0)  # 假设输入张量是第一个绑定
output_name = engine.get_tensor_name(1)  # 假设输出张量是第二个绑定
设置张量地址
context.set_tensor_address(input_name, int(input_buffer))
context.set_tensor_address(output_name, int(output_buffer))
创建 CUDA 流
stream =cuda.Stream()
异步将输入数据从主机拷贝到设备(cudaMemcpyAsync)
# input_data = np.random.rand(*input_size).astype(np.float32)
# input_data = inputs[0].ravel()
input_data = inputs
cuda.memcpy_htod_async(input_buffer, input_data, stream)
执行推理
context.execute_async_v3(stream_handle=stream.handle)
获取输出数据
outputs = np.empty(output_size, dtype=np.float32)
cuda.memcpy_dtoh_async(outputs, output_buffer, stream)
stream.synchronize()
preds = torch.from_numpy(outputs)
return preds
Thank you very much!!!!
Which batchsize (or dynamic?) do you use for building the engine?
I just specified batch_size in my input, and used the batch_size parameter when building and opening up space, but batch does not seem to be used when building the engine. I should add some code when building the engine to achieve dynamic batch>1 Inference model input? Thank you very much!
import tensorrt as trt
设置日志记录器
定义 ONNX 文件路径和输出的 .plan 文件路径
onnx_file_path = “your_model_dynamic.onnx” # 替换为你的 ONNX 模型路径
plan_file_path = “/JHC/dynamic_model.plan” # 替换为保存的 TensorRT 引擎路径
创建 TensorRT Builder、Network 和 Parser
builder = trt.Builder(logger)
network = builder.create_network(flags=trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
parser = trt.OnnxParser(network, logger)
解析 ONNX 模型
print(“Parsing ONNX model…”)
with open(onnx_file_path, “rb”) as f:
if not parser.parse(f.read()):
print(“Failed to parse the ONNX model.”)
for i in range(parser.num_errors):
print(parser.get_error(i))
exit(1)
创建构建配置
config = builder.create_builder_config()
config.set_memory_pool_limit(trt.MemoryPoolType.WORKSPACE, 1 << 30) # 设置最大工作空间为 1GB
添加优化配置文件以支持动态 batch
profile = builder.create_optimization_profile()
input_name = network.get_input(0).name
input_shape = network.get_input(0).shape
假设输入形状为 (batch_size, C, H, W)
设置动态 batch 范围,例如 [1, 8]
min_shape = (1, *input_shape[1:])
opt_shape = (4, *input_shape[1:])
max_shape = (8, *input_shape[1:])
profile.set_shape(input_name, min_shape, opt_shape, max_shape)
config.add_optimization_profile(profile)
构建引擎
print(“Building TensorRT engine…”)
engine = builder.build_serialized_network(network, config)
保存 .plan 文件
if engine:
with open(plan_file_path, “wb”) as f:
f.write(engine)
print(f"TensorRT engine saved as {plan_file_path}")
else:
print(“Failed to build the TensorRT engine.”)
this is my onnx to tensorrt code
thank you!
To check this issue further, could you attach the source that allows us to reproduce the issue on our end?
Including the ONNX file, inputs, converting, and comparing script.
