Why is my NVIDIA driver loaded but not detected by X.org?
I’m using a Debian 10 system with X.org installed, LightDM as display manager and GNOME as desktop environment. When I start LightDM, only one physical display starts. I have two displays, one internal, driven by my integrated intel graphics, one external HDMI, driven by my discrete nvidia graphics. I have set up NVIDIA optimus using bumblebee/primus, so I can use my integrated intel graphics to drive the display whilst running applications on my discrete card. When I start LightDM, the X server only uses the internal screen whilst my monitor remains in standby. I need to use an Xorg config file even though its not recommended because otherwise Xorg won’t detect my external display.
/etc/X11/xorg.conf:
Section "ServerLayout"
	Identifier     "X.org Configured"
	Screen      0  "Screen0" 0 0
	Screen      1  "Screen1" RightOf "Screen0"
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
	ModulePath   "/usr/lib/xorg/modules"
	FontPath     "/usr/share/fonts/X11/misc"
	FontPath     "/usr/share/fonts/X11/cyrillic"
	FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/Type1"
	FontPath     "/usr/share/fonts/X11/100dpi"
	FontPath     "/usr/share/fonts/X11/75dpi"
	FontPath     "built-ins"
EndSection
Section "Module"
	Load  "glx"
EndSection
Section "InputDevice"
	Identifier  "Keyboard0"
	Driver      "kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "auto"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "Monitor Model"
EndSection
Section "Monitor"
	Identifier   "Monitor1"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
        ### <percent>: "<f>%"
        ### [arg]: arg optional
        #Option     "Accel"              	# [<bool>]
        #Option     "AccelMethod"        	# <str>
        #Option     "Backlight"          	# <str>
        #Option     "CustomEDID"         	# <str>
        #Option     "DRI"                	# <str>
        #Option     "Present"            	# [<bool>]
        #Option     "ColorKey"           	# <i>
        #Option     "VideoKey"           	# <i>
        #Option     "Tiling"             	# [<bool>]
        #Option     "LinearFramebuffer"  	# [<bool>]
        #Option     "HWRotation"         	# [<bool>]
        #Option     "VSync"              	# [<bool>]
        #Option     "PageFlip"           	# [<bool>]
        #Option     "SwapbuffersWait"    	# [<bool>]
        #Option     "TripleBuffer"       	# [<bool>]
        #Option     "XvPreferOverlay"    	# [<bool>]
        #Option     "HotPlug"            	# [<bool>]
        #Option     "ReprobeOutputs"     	# [<bool>]
        #Option     "XvMC"               	# [<bool>]
        #Option     "ZaphodHeads"        	# <str>
        #Option     "VirtualHeads"       	# <i>
        #Option     "TearFree"           	# [<bool>]
        #Option     "PerCrtcPixmaps"     	# [<bool>]
        #Option     "FallbackDebug"      	# [<bool>]
        #Option     "DebugFlushBatches"  	# [<bool>]
        #Option     "DebugFlushCaches"   	# [<bool>]
        #Option     "DebugWait"          	# [<bool>]
        #Option     "BufferCache"        	# [<bool>]
	Identifier  "Card0"
	Driver      "intel"
	BusID       "PCI:0:2:0"
EndSection
Section "Device"
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False"ss,
        #Option     "SWcursor"           	# [<bool>]
        #Option     "HWcursor"           	# [<bool>]
        #Option     "NoAccel"            	# [<bool>]
        #Option     "ShadowFB"           	# [<bool>]
        #Option     "WrappedFB"          	# [<bool>]
        #Option     "GLXVBlank"          	# [<bool>]
        #Option     "SwapLimit"          	# <i>
        #Option     "AsyncUTSDFS"        	# [<bool>]
        #Option     "DRI"                	# <i>
	Identifier  "Card1"
	Driver      "nvidia"
	BusID       "PCI:1:0:0"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen1"
	Device     "Card1"
	Monitor    "Monitor1"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
lspci | grep NVIDIA to show my graphics are detected:
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f99 (rev a1)
lsmod | grep nvidia to show that the nvidia drivers are loaded:
nvidia_modeset       1232896  1
nvidia              34164736  18 nvidia_modeset
My LightDM config file has no xserver-config field set so it will use /etc/X11/xorg.conf
I can’t post the entire X.org log as it’s too many characters. The three most notable lines are:
[  9581.561] (II) LoadModule: "nvidia"
[  9581.562] (WW) Warning, couldn't open module nvidia
[  9581.562] (EE) Failed to load module "nvidia" (module does not exist, 0)
I have two questions:
  1. Why is my graphics card detected by lspci and the drivers by lsmod, but Xorg says that the driver doesn’t exist?
  2. How can I make it so that X.org does detect the drivers?
P.S.: The nouveau drivers are not loaded, and not mentioned in the Xorg config so they shouldn’t be an issue.
I’m also working on fixing an Optimus setup with Debian. Previously had it working with Bumblebee, but upgraded to Debian 11 and trying to get Prime offload to work. After experiments with my system, I’m wondering what happens for you if you just remove the two lines specifying BusID from your Device sections in xorg.conf? There are a lot of odd automated things happening with the drivers now…
Oh wait, that might not work if you don’t use kms. How did you install your drivers?
