and if reboot i get the following xorg xserver error:
(the nouveau driver is correctly blacklisted)
[ 93.113] Module class: X.Org Server Extension
[ 93.113] (II) NVIDIA GLX Module 390.67 Fri Jun 1 03:10:40 PDT 2018
[ 93.113] (II) LoadModule: “nvidia”
[ 93.113] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 93.113] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 93.113] compiled for 4.0.2, module version = 1.0.0
[ 93.113] Module class: X.Org Video Driver
[ 93.113] (II) NVIDIA dlloader X Driver 390.67 Fri Jun 1 02:45:19 PDT 2018
[ 93.113] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 93.113] (II) systemd-logind: releasing fd for 226:0
[ 93.114] (EE) No devices detected.
[ 93.114] (EE)
Fatal server error:
[ 93.114] (EE) no screens found(EE)
[ 93.114] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 93.114] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 93.114] (EE)
[ 93.120] (EE) Server terminated with error (1). Closing log file.
i tried the Xorg Config from your link but this did not work… the computer starts then it flickers in the console after 5 minutes the flickering stops and i can switch to a working console with Alt-Fx
maybe i should say that it’s a hybrid graphic card Laptop where as far as i know the Laptop Screen is attached to the Intel Coffeelake Graphics and the external HDMI Screen is attached to the NVIDIA Card
The log is still empty but you’re running kernel 4.16 now. The xorg log tell that you have some kind of strange config files maybe in /etc/X11/xorg.conf.d so you’re running two screens which doesn’t work.
have you a hint how to run two cards with one screen, because the Xorg -configure generated this and i also tried to create a correct config file with nvidia-xconfig --enable-all-gpus
