I used the same code to reason cyclegan in orin nano and nano, but orin nano requires around 0.28s and nano requires around 0.24s. When I added in the time to transfer the data cpu to the gpu, the orin nano was much faster than the nano.
But I think the orin nano should also reason faster, and I wonder what I should do?
Thanks for visiting the forums. Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Have you tried to maximize the device’s performance?
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
