I just bought a dell mobile workstation with the top mobile GPU option: NVIDIA RTX A5000 Laptop.
After receiving it, I found that everything is OK, but the ECC function is “N/A” in the output of “nvidia-smi -q”. My driver version is 470.86.
Is this a normal case?
If A5000 Mobile, as a professional card, does not have the ECC function, what is the difference between it and 3080 Mobile? Their metrics are almost the same.
==============NVSMI LOG==============
Timestamp : Fri Jan 7 19:45:48 2022
Driver Version : 470.86
CUDA Version : 11.4
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA RTX A5000 Laptop GPU
Product Brand : NVIDIA RTX
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Disabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-7ce20bc1-bec0-6ab6-5a5c-e6573926bd07
Minor Number : 0
VBIOS Version : 94.04.42.40.08
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Module ID : 0
Inforom Version
Image Version : G001.0000.03.03
OEM Object : 2.0
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x24B610DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x0A691028
GPU Link Info
PCIe Generation
Max : 4
Current : 4
Link Width
Max : 16x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : N/A
Performance State : P0
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 16125 MiB
Used : 5 MiB
Free : 16120 MiB
BAR1 Memory Usage
Total : 16384 MiB
Used : 3 MiB
Free : 16381 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 48 C
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 87 C
GPU Target Temperature : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : N/A
Power Draw : 27.28 W
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 1455 MHz
SM : 1455 MHz
Memory : 6000 MHz
Video : 1275 MHz
Applications Clocks
Graphics : 1455 MHz
Memory : 6001 MHz
Default Applications Clocks
Graphics : 1455 MHz
Memory : 6001 MHz
Max Clocks
Graphics : 1635 MHz
SM : 1635 MHz
Memory : 6001 MHz
Video : 1425 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 725.000 mV
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 1512
Type : G
Used GPU Memory : 4 MiB
