• Hardware Platform (A100)
*• DeepStream 7.1
• NVIDIA GPU Driver Version: 560.28.03 CUDA Version:12.6
• questions
I tried using nvjpegdec
to decode JPEG images for inference, but I found that the decoding speed with nvjpegdec
is much slower than with jpegdec
(although jpegdec
uses more CPU resources). Is this reasonable, or is there something wrong with my implementation?
CUDA_VISIBLE_DEVICES=4 USE_NEW_NVSTREAMMUX=yes gst-launch-1.0 filesrc location='3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_0 nvstreammux name=m batch-size=16 config-file-path='./stream_mux_config.txt' ! nvinfer config-file-path='dstest1_pgie_config.txt' ! fakesink enable-last-sample=False filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_1 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_2 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_3 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_4 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_5 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_6 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_7 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_8 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_9 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_10 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_11 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_12 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_13 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_14 filesrc location= '3840_2160.jpeg.1000' ! nvjpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_15
Execution ended after 0:04:45.499731357
top command show %CPU about: 90%
CUDA_VISIBLE_DEVICES=4 USE_NEW_NVSTREAMMUX=yes gst-launch-1.0 filesrc location='3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_0 nvstreammux name=m batch-size=16 config-file-path='./stream_mux_config.txt' ! nvinfer config-file-path='dstest1_pgie_config.txt' ! fakesink enable-last-sample=False filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_1 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_2 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_3 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_4 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_5 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_6 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_7 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_8 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_9 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_10 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_11 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_12 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_13 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_14 filesrc location= '3840_2160.jpeg.1000' ! jpegdec ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! m.sink_15
Execution ended after 0:00:53.613020919
top command show %CPU about: 1300%
