If you remove the NVCC option which builds debug device code (-G) from the OptiX SDK example build process, the OptiX kernels will be as fast as in release mode while you still can debug your host code the same way in debug targets.
This post describes how: https://forums.developer.nvidia.com/t/a-problem-when-i-want-to-createmodule/276228/2
My OptiX example framework always builds release device code by default for both release and debug targets.
If the OpenGL context of your application is not running an NVIDIA implementation, then there cannot be CUDA-OpenGL interop with the device running the OptiX/CUDA raytracing code.
There are multiple ways to solve that:
The best would be to change the OpenGL pixelfomat selection to not use the standard Windows functions but the OpenGL WGL extensions to enumerate all pixelformats and pick one which is provided by the NVIDIA driver implementation.
Using these WGL functions instead of the Windows ChoosePixelFormat
https://github.com/KhronosGroup/OpenGL-Registry/blob/ca491a0576d5c026f06ebe29bfac7cbbcf1e8332/api/GL/wgl.h#L297C13-L297C42
Since the OptiX examples use GLFW as window framework there is probably also a way to set some hints before creating the GLFW window to steer the application to use an NVIDIA OpenGL implementation.
Look at the Window and Context documentation here: https://www.glfw.org/documentation.html
Other methods would force either your application or your whole system to run the graphics on the discrete GPU.
Please have a look into the NVIDIA Display Control Panel application and look at the 3D Settings → Manage 3D Settings.
(I’m running Quadro workstation boards and don’t know how this differs on GeForce. I’m currently looking at a laptop with integrated and discrete GPUs.)
There should be Global and Program settings tabs.
Inside the Global settings there is a Preferred graphics processor combo-box then.
Try changing that from auto-select to the NVIDIA processor.
(I have that set to auto-select and my OptiX programs work just fine.)
Inside the Program tab you can do the same for each executable individually.
I’m not sure if you need to do that for your executable or if it’s enough to do that for the Visual Studio executable as long as you start your applications from inside that.
Again, things work just fine out-of-the box on my iGPU + dGPU laptop but it’s a workstation system and with the provided information it’s unclear why your system behaves differently.
