(1) Some pins, such as UART3_TX, UART3_RX, UART3_RTS, UART3_CTS, CAN1_DOUT, CAN1_DIN, CAN0_DOUT and CAN0_DIN as their relative IC Ball Name, surely are controlled by the corresponding register with HSIO/GPIO select bit, but have no GPIO function in pinmux document, can’t they be configured as a GPIO?
(2) If they can, in which bank should they be?
(3) Pin 17(CAN1_DOUT) and pin 15(CAN1_DIN) of j26 on tx2 function as GPIO. The source code
you may need to configure [Customer Usage] column to set the pin as unused and also change the [Pin Direction].
there were three device tree generated from spreadsheet.
please follow the documentation, Jetson TX2 Pinmux and GPIO Configuration to update the board.
could you please also share your use-case,
thanks
We want configure UART3_TX, UART3_RX, UART3_RTS and UART3_CTS as GPIO. Their registers all have GPIO/SFIO select bit. Why we can’t find GPIO function of them in spreadsheet? So that we can’t automatically generate dtsi file.
As documentation described,
MB1 only allows writes to the pinmux and GPIO address range. prod setting is the configuration of system characterization, interface, and controller settings.
you may also refer to Jetson TX2 Boot Flow for the flow of control in MB1.
Such these settings in the device tree (dtsi file) are still applied by the kernel.
hope this helps,
thanks
Provided UART3_TX corresponds to pin8 in J21. I tried to configure it as GPIO following below steps,
(1) change tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg file
I am adding some more data to JerryChang’s reply for your reference.
Yes most but not all of the pins on 40-pin header can be configured as GPIO.
And some of them are preset to SFIO based on user requirements and some pins are forced configured as SFIO.
Bank:
This is tricky. Because the pinmux spreadsheet is prepared based on user requirements, so the GPIO selection is not provided for few of them. If you want to know the particular GPIO bank and port, here is a quick hack.
Check in the pinmux cfg source. (say $TEGRA_TOP/bct/t186/pinmux/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)
Say you are trying to configure CAN1_DOUT pin as GPIO.
Now look for “can1_dout” under the section #### Pinmux for used pins ####
The entry is:
pinmux.0x0c303008 = 0x00000400; # can1_dout_pz0: can1, tristate-disable, input-disable can1_dout_pz0 this tells that GPIO configuration is (Z, 0)
Both xxx_pinmux_xxx.dtsi and tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg can configure pin function. What the relation between them?
Pinmux is configured during MB1 which is early boot phase. For MB1, the configuration tables are supplied with *.cfg. Our earlier SoCs which has dtsi settings configured in kernel, use dtsi version.
That means one pin configured as GPIO in pinmux BCT file while as SFIO in dtsi file will finally be GPIO. But the BCT file is loaded prior to the dtsi. That makes me confused.
In the Jetson-TX2-Series-Pinmux-Template.xlsm Revision 1.00 there is the PEX_CLK pins A44, A45, A41, A42, B45, B46. These are all listed under the first sections before you get to the “Dedicated SFIOs” section on row 249. Similarly, under the EDP section there are pins B35, B34, A35, and A34. Cells AQ234 and AQ235 make it look like they can be configured between I2C6_CLK/DAT and DP_AUX_CH0_P/N. However, I can’t find the proper pinmux register for any of these pins.
Are any of these pins pinmux configurable?
Can they be configured as GPIOs?
If not, why are they not listed in the “Dedicated SFIOs” section?
Please just give me a hints an tips about how to configure UART3_TX(IC ball name) as GPIO if it can be? Our intense work schedule is obstructed by this GPIO issue greatly.
Following pins on 40 pin header, they are going to level shifter which restricts their direction.
Pin 8 UART1_TXD_HDR_3V3 DIR → OUT
Pin 10 UART1_RXD_HDR_3V3 DIR → IN
Pin 11 UART1_RTS_HDR_3V3 DIR → OUT
Pin 36 UART1_CTS_HDR_3V3 DIR → IN
So the pins whose DIR is OUT, voltage can be Low/High in OUT state of GPIO, cannot drive the pin in IN state.
Same goes with Pins in IN DIR. Direction of these pins cannot be changed as they are hardware restricted.
I think you have the signal connection path incorrect. From your earlier post #8, it looks like you are trying to control the J21 expansion header pin 8. Correct?
Here is the hardware path from the Jetson TX2 SoM to that pin:
Jetson TX2 H12 pin → UART0_TXD → UART MUX (U8) → UART0_TXD_HDR_1V8 → Level Shifter (U5) → UART1_TXD_HDR_3V3 → J21 pin 8
So if you want to control J21 pin 8, you need to configure the GPIO for pin H12 on the SoM. This maps to the IC Ball Name UART1_TX and is controlled by PADCTL_DEBUG_UART1_TX_0 @0x02435018. This corresponds with GPIO Port T.00 (GPIO #464).
Therefore, all you need to do is set GPIO #464 properly to the value you would like in order to control J21 pin 8. For example:
The only way UART1_TXD_HDR_3V3 maps to UART3_TXD (still not Tegra UART3) is if you have populated a jumper for R79 and removed the jumper at R80 on your development kit.
I’ve went ahead and updated the existing spreadsheet to include all of the GPIOs properly listed. See the attached unofficial v1.01 of the spreadsheet.
[This file was removed because it was flagged as potentially malicious] (1.1 MB)
