**• Hardware Platform (Jetson / GPU)Tesla T4
**• DeepStream Version 5.0.1
**• TensorRT Version 7.0.0
**• NVIDIA GPU Driver Version (valid for GPU only)10.2
below are some of my images and config files
CPU:
GPU:
Run Result:
Config File:
deepstream_app_config_yoloV5_Helmet.txt (35.0 KB)
Can you use “nvidia-smi dmon” to monitor the GPU and CPU loading?
Fiona.Chen:
nvidia-smi dmon
thanks.Is this because the encoder of the graphics card is already fully loaded? Has nvidia officially tested the maximum number of rtsp streams that the Tesla T4 can encode at the same time?
The HW encoder is fully occupied by the 40 streams encoding for RTSP streaming.
I know,how many rtsp streams can be HW encode in Tesla T4?
Depends on the resolution and encoding parameters. You can try to test.
