i have install deepstream 6.0 on jetson agx xavier
but when i look onto this location i got two directory
- deepstream
- deepstream-6.0
when i checked both has same files but when i clone deepstream-reference-app they give me this path for cloning config file
/opt/nvidia/deepstream/deepstream/samples/configs/tao_pretrained_models/
but why not we use use deepstream-6.0
/opt/nvidia/deepstream/deepstream-6.0/samples/configs/tao_pretrained_models/
so i removed deepstream folder then i run deepstream-reference -app
but this got me error
/opt/nvidia/deepstream/deepstream-6.0/samples/configs/tao_pretrained_models$ sudo deepstream-app -c deepstream_app_source1_detection_models.txt
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
dlopen error: /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so: cannot open shared object file: No such file or directory
gstnvtracker: Failed to initilaize low level lib.
** ERROR: <main:707>: Failed to set pipeline to PAUSED
Quitting
App run failed
what should i do how to clean uninstall deepstream and reinstall why the refrence app is not running without deepstream folder why cannot run from deepstream-6.0 folder ???
